2 members (baldeagle, Hotrod Lincoln), 110 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#1535066 02/01/2024 4:56 PM
I`d like to add a heater to my existing Harrison heater in my 1959 Apache. What options are out there?
I found THIS ONE but wanted more info, maybe more heat. I`d like to drive mine all year.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Guitplayer, As your question involves the most specifically the interior of your truck, I've moved the post over to the Interiors forum for the best replies and further conversation on the topic. wink
~ Dan
1951 Chevy 3 window 3100
Thanks. I could not find an appropriate forum for my heater.
~ BD.
What do you mean when you say you are adding a heater to an existing Harrison heater? One heater is plenty to heat up the small cab of a pickup. I have one of those basic recirculating heaters and it heats up the cab in the coldest weather (teens) and gets it so hot I have to turn it off sometimes.
$230 is pretty steep, too. I bet you could find a used one somewhere for much less.
1950 Chevrolet 3100 (Ol' Roy)
I will say my 1958 panel came with 2 heaters. I don`t how or where the 2nd was mounted. The pic, you can see the 4 heater hoses under battery. I took this pic when I first got the hood open and off. Wonder where that 2nd heater was mounted? Under the dash would be best for that or
an after market heater.
~ BD.
Otto, he has a panel truck so not a typical cab but more like a minivan space to heat.
1949/50 3600 Project
Follow in Project Journals
Aah, I see.
In fact the additional heater that came in the 58 panel is slightly different in that it does not have a directional "scoop" at the bottom. I wonder could it be factory. The extra holes in firewall are not centered. The other pic is the length of the hoses ....
~ BD.
That looks like a tidy , fairly compact unit. It has an unobtrusive appearance.
A used heater , one that has seen a fair amount of use then been idle for a spell ; I’d be concerned about the integrity of the core. Better to spend a few more dollars for a new unit , methinks.
Yes, I have one good core left and heater that I will use in the 235 1958 panel.
This would be for my 59 Panel. I have a power inverter in the truck and was using
a space heater while I was working on it.
So I am looking at horizontal heaters that I can mount under the dash and
have 120v.
It would be instant heat and I would be able to remove it after the cold season.
Thoughts...?
~ BD.
That's gotta be a "powerful" inverter!
Yeah, I`ve had that invertor for at least 34 years now. I used it to power key machines.
The heater has a 500-1000-1500 watt options. My invertor is 1500 watts.
~ BD.
I dont know about your panel but I've seen suburbans with the second heater under the rear seat. If you get a compact one, will it fit under the driver seat?
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
Thanks , yes my 58 came with 2 heaters. Under the seat? Drivers?
Here are the 4 hoses. But the 2nd heater was behind the seat. Just there
Holes on the firewall
~ BD.
Moderated by  ndkid275, Phak1
