0 members (),
54
Mod | | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 271 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 271 | 1957 235 has different part number than 58^ What is the difference other than looks? Also will a 216 fuel pump work on 57 235? Have a 57 block Thanks
| | | | | Joined: Dec 2020 Posts: 1,959 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,959 | This works on my 57 235 -- Delphi MF0073 Mechanical Fuel Pump
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | One difference is how the inlet and outlet of the pump is clocked. The other difference may be in the size of the check valves. The later valves may be larger then 57 and earlier.
Mike
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | The difference in the clocking of the ports is to clear the mid-engine motor mounts on later model engines. The pumps are the same, block mounting, lever arm, internally, and pressure-wise, IMHO. Jerry
| | | | | Joined: Oct 2012 Posts: 271 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 271 | Thanks Jerry. I tried the pump off the 58 and it won't make pressure on the motor. But it will make pressure working it by hand. I am turning motor over by hand on engine stand but I would think it would make some kind of pressure. Only other difference I noticed was 216 advertising 15 GPH were as 235 is 20 or 25 depending on pump number. Napa gas a pump for a 216 on the shelf and its half the price of the 235 pump for a 57?
| | | | | Joined: Oct 2021 Posts: 6,759 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,759 | Have your original pump rebuilt. Any new one you buy will be junk from China that doesn't work.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Oct 2012 Posts: 271 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 271 | Thanks for the input and answers. I got back from lunch and hooked a vacuum gauge to input and output. Gauge moved. Not much but pulsing. I'm going to go for it. I'm sure these pumps probably never pumped a lot of pressure maybe 3-5 lbs. | | | | | Joined: Oct 2021 Posts: 6,759 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,759 | Yes. I believe the range should be 2-4 psi. My fuel pump is 2.5psi at the carburetor.
