0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#1534826 01/30/2024 10:20 PM
A buddy has an about 1920 GMC 11/2 ton tow truck that needs some parts, it has a inline six with split heads.
Is anybody familiar with these engines
good planning is no substitute for dumb luck
3B Offline
Hy panel fan, according to GMC the first hundred years, by John Gunnell, "in 1921, General Motor Truck Co. switched from Continental engines to engines built by Northway Motor Division of GM, which was based in Detroit." Hope that gives you a point to start searching from.
3B #1534983 01/31/2024 11:47 PM
Thanks you. Every bit of information helps, the search goes on.
