5 members (lumbersawyer, tclederman, TUTS 59, 39Master85, 1 invisible), 38 guests, and 3 robots.
Topics128,083
Posts1,056,331
Members48,442
#1534537 01/28/2024 4:40 PM
Hello, I’m working on 50 chevy3100. I’m changing to bendix brakes on front and need info on the stems that come out of the wheel cylinders. Trying to find them locally but don’t have any to compare size or shape.Does anyone know a part number or how to find them? Also will my rubber brake hoses from huck brakes work on bendix?
Thanks, Rick
Do you have a picture or a diagram showing which part you need? I am not sure what a "stem" is in this context.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Rick, Correct me if I’m wrong, but are asking about the “bleeder valve”???
~ Dan
1951 Chevy 3 window 3100
I think he is referring to the part that pushes from the wheel cylinder to the brake shoe that are separate on bendix brakes but part of a huck brake cylinder.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
The brake hoses as far as rock auto (you can double check ) show the same hose part numbers for a 1949 as well as a 1952 .If no one has a part number for the push pins for the bendix brakes I can dig out a few I have and throw a few pictures on here .
"The Journey"
Follow in the DITY
Kevinski that is the part I am talking about, I heard them called stems,push pins, and links. The rubber line does screw into the wheel cylinder,so I’m going to try it. Thanks
Okay .i will take a look in the garage to get you a size picture ,also I think the drums are different between huck and bendix
"The Journey"
Follow in the DITY
Here ya go I don’t know if they are from the front or rear but I had a few and I think they are all the same between front and rear. The slot is the thickness of the metal part of the shoe.
"The Journey"
Follow in the DITY
IIRC, the ones I used on my '51 3100 with Bendix brakes look just like the ones that Kevinski posted.
It looks like NAPA has them, but they say they don't fit. I think that's incorrect.
Thanks guys, I believe those are the ones I bought from Napa
