1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#1533451 01/19/2024 10:16 PM
2 Offline
When temp lever is all the way down does produce cooler air or maximum heat, I looked in the shop manual but couldn't find anything about it . This on my 56 chevy 6100 , thanks Mark.
1956 Chevy 6100 with a dump box
Story in Big Bolts
1949 ford 8n tractor
1958 861 diesel ford tractor
2003 honda vtx 1800 c bike
V
VEW Offline
V Offline
Down is more heat, assuming everything is working properly.
The control arms have a tendency to break off. Make sure your cables move freely.
~ Victor
1957 3100 - moved on
VEW #1533458 01/19/2024 11:09 PM
2 Offline
Thanks V , I'm glad to hear down is heat I spent the day freeing up the cables except that one. It looks to be a struggle and since it's winter it can stay where its at.
Story in Big Bolts
V
VEW Offline
V Offline
I noticed you’re in MN and figured you would be happy to hear it is stuck in the high heat position. Doesn’t look like you will need to deal with it anytime soon 😊
~ Victor
VEW #1534135 01/25/2024 9:44 AM
2 Offline
Thanks I was but the thought of one stuck cable bugged me so I did get it disconnected and freed up , it wasn't as bad a job as I thought it would be. thumbs_up
Story in Big Bolts
