0 members (), 133 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
Just getting started on a restoration of a '57 Chevy 3100. Lots of old British car knowledge but my first dive into domestic iron.
I know where the engine block drain is, but this thing seems bizarre. Could a P.O. have drilled and tapped the block to provide another drain?
I hate to remove it until I have an idea what it might be. And that is a wooden dowel on the end of the rubber hose, not a cork.
Thanks in advance for your shared wisdom!
1957 3100, 235 with 4 speed floor shift
3100inSantaFe, 1st off, Welcome to Stovebolt! wave That being said, your question belongs in the Engine Shop so that where it has been moved for the best answers and further conversation. thumbs_up
~ Dan
1951 Chevy 3 window 3100
That's the oil canister return line. Someone removed the oil filter and plugged the line. Remove that contraption and screw in a 1/8 inch pipe plug
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
No no no...too high...look in picture at bottom. That is an Oil line.. that looks to be where a Brass Plug should be?
Is this a 235 engine or???
Todd
1950 Chevy 3100
Could be were an old circulating block heater hooked up but I thought those taped onto an existing hose .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Iit the return for the heater or one that use to be there.
Jay D.
Very well could be a circulating block heater connection. Looks like someone has installed an adapter in the core plug opening and tapped that for a pipe nipple. There would be another connection (maybe a tee in a heater hose) for a return.
That was where a block heater was on my 216. But that was an insertion type heater with just the cord sticking out.
It is a 235. I should have mentioned that! It has an 'accessory' style heater that mounts on the firewall. A donut style heater core with the blower motor in the center. I found the heater shown in a Chevrolet Accessory manual. But that manual did not describe where the hoses were to be installed. On this engine, one heater hose was connected to a port on the water pump. The other was connected to a port on the thermostat housing. So maybe the mystery part was used for the heater possibly before the PO found the option of either the water pump or thermostat housing port?
So, a follow-up question. Where the pipe is connected to the block, could this be actually cast into the block? (and threaded?) I have looked at photos of blocks and never saw that option.
Thanks again!
Just seen your location so if the truck was from the area most likely not for a recirculating block heater unless I am wrong about your weather
"The Journey"
Follow in the DITY
7
7 Offline
It is difficult to see from the original pic, almost looks like it could be a rubber expansion plug with a modified port?
Regardless of what it was used for, remove it and replace it with a core plug or a solid rubber expansion plug.
While you have it out you can do a thorough flush of the block.
1950 Chevrolet 3100 (Ol' Roy)
Thanks to all! I removed the rubber hose and clamps and as mentioned, this appeared to be a block drain. The 3/8 pipe nipple seemed to be firmly corroded in place so I chased the threads on the nipple, then used a galvanized clamp and Teflon tape and all seems well. Thanks for all of your help!
