7 members (Southerntruck, jaycoop, Joe H, WICruiser, 2-Ton, 42465967, Shade Baby),
114
Mod | | | Forums66 Topics128,129 Posts1,056,362 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | I recently purchased 2 30" Smithy's mufflers from a Calif supplier. When I opened them up they were a purtty blu color. As I was checking them over I notice that the Smithy logo stamped in the metal casing WAS ON BACKWARDS as was the INLET arrow?? When I put them on they sounded funny. So I turned them around and they sounded better. My question is looking down the end of the pipe that says inlet the perforated openings are facing down the pipe. However the muffler sounds better turned around which would make the little openings inside the pipe point towards the exhaust manafold. Which is the right way anybody know?
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | I don't know about the smittys, but if you look into the inlet of a standard glasspack, the "louvers" face backwards toward the outlet. I have read that turning a glasspack around will make it produce more of a "bark" sound when revved. I'll double check mine and get back here.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
| | | | | Joined: Sep 2000 Posts: 6 Member | | Member Joined: Sep 2000 Posts: 6 | What motor you have upstream of your Smithys? | | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Fresh rebuilt 060 over 59 235. The exhaust sounds better with the Smithys reversed as you say.
| | | | | Joined: Jan 2001 Posts: 20 Member | | Member Joined: Jan 2001 Posts: 20 | I am running Smitty's behind my 235 in my 54 Bel Air they don't rapp like the old ones I remember, When I questioned this to Rod and Custom supply they said, when they started repops they louvered them that way on purpose so they wouldn't be so loud. Go figure, by this time my exaust was already welded up. My 48 Aerosedan runs 18 in. glass packs now this sucker raaaaaapppppppppsss!!!!! Thanks Mick Inniss  [ 12-01-2001: Message edited by: mick inniss ] | | |
