| | | Forums66 Topics128,164 Posts1,056,968 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | Building a hotrod out of 1941 coe. It has a s10 frame and fuel tank. 350 Chevy engine needs 5 to 7 psi s10 pump puts out alot lot more don’t remember how much so i put a seperate fuel pump on it. In need to use a 0-90 ohm fuel sender for fuel gauge the s10 sender is like 240 omh is there 1 that will fit in the tank where the s10 sender is now? Thanks for any help
