7 members (Samantha, cmayna, 55shaker, Bill Hanlon, TooMany2count, 1955 1 Series, Otto Skorzeny), 102 guests, and 3 robots.
Topics128,071
Posts1,055,901
Members48,429
#1533686 01/22/2024 3:02 AM
Hi All,
I have a 1950 1/2 ton truck. I have searched and seen diagrams of how the defroster duct attaches to the sheet metal but I cannot figure it out. The two duct I have are two different size which I believe is correct. They both have one sheet metal clip and one hole for a screw. I have looked under the dash and just do not see how and where the sheet metal clips attach? Can someone post a picture of the ducts mounted in place? There does not seem to be a feature for the clips to slide onto. I should note that my truck never had a heater or the ducts. I am installing one of the deluxe heaters.
thanks in advance,
Skipper
rc356s #1533689 01/22/2024 3:09 AM
The clip slides in to the dash defrost opening.
rc356s #1533709 01/22/2024 4:48 AM
Here's a couple of pics of defrost outlet mounting.
Driver's side from the top.
Passenger side from the bottom
rc356s #1533711 01/22/2024 4:59 AM
Thank you that is clear. I thought of that but thought it may interfere with the trim if it is mounted in that way. I guess the trim should fit without any issue.
rc356s #1533752 01/22/2024 5:20 PM
Professional procrastinator
The only issue you will have is if you use a screw that is too long. IIRC, about half an inch long were the screws in my truck.
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
rc356s #1533808 01/23/2024 12:50 AM
The windshield trim fits over the opening, and has a slot in it to direct the air to the windshield. Like Twin Jimmys said, use a short screw.
Moderated by  ndkid275, Phak1
