1 members (Eileen), 271 guests, and 2 robots.
Topics128,101
Posts1,056,181
Members48,436
#1533478 01/20/2024 1:35 AM
Hi there, can someone tell me how to remove the wiper knob from the dashboard of a 47-53 Chevy 3100 Panel truck ? I dont want to ruin it. Thanks!
There's a nut underneath holding the assembly on. The knob itself doesn't come off easily. Best to remove the whole knob/lever assembly.
Moderator, Electrical Bay
Some are metal, some are bakelite/hard plastic. Some have a set screw and others were molded to the lever when they were made. Much variation exists. The metal ones can generally be pulled off carefully. The plastic/bakelite ones will often break because they can be pretty brittle and I've not had much luck separating those from the lever...good luck! As Kevin says it is best to remove the whole assembly.
~ Jon
Moderated by  ndkid275, Phak1
