1 members (Eileen),
271
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | Hi there, can someone tell me how to remove the wiper knob from the dashboard of a 47-53 Chevy 3100 Panel truck ? I dont want to ruin it. Thanks!
| | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | There's a nut underneath holding the assembly on. The knob itself doesn't come off easily. Best to remove the whole knob/lever assembly.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2014 Posts: 4,491 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,491 | Some are metal, some are bakelite/hard plastic. Some have a set screw and others were molded to the lever when they were made. Much variation exists. The metal ones can generally be pulled off carefully. The plastic/bakelite ones will often break because they can be pretty brittle and I've not had much luck separating those from the lever...good luck! As Kevin says it is best to remove the whole assembly.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
