1 members (Peggy M), 74 guests, and 0 robots.
Topics128,094
Posts1,056,064
Members48,433
#1533038 01/15/2024 10:17 PM
Hi all,
I finished all of the front end/suspension work on my 53 Chevy 3100 1/2 ton. Now starting on the body work. I want to disassemble the bed for ease of workability and have the left/ride bed side panels separated to lay flat. Currently, the rear cross member looks to be spot welded to each side panel. Is it okay to grind down the welds to get the cross member separated? Was it originally welded in place by the factory, or is this someone else's handywork?
1953 Chevy 3100 1/2 Ton Pickup
Doug
Pilot: it’s welded like that from the factory; my 1948 bed had similar welds. In fact, I replaced the 48 bed with a 1987 stepside bed: still welded in the same way. I’m sure the factory felt that simply bolting that rear sill to the bedsides was not sufficient to keep everything square.
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
What Flatblu4748 said. My '51 bed was also welded there. I rewelded there after restoring the bedsides and installing a new rear cross-sill and the destroyed stake pocket (pic). Yours looks in way better shape. You can carefully grind those welds away to disassemble it.
I'll move this thread over to Making a Stovebolt Bed where it'll be more on topic.
Thanks Kevin, I'll tackle this tomorrow. MIne obviously doesn't have the rust damage that I've seen some on other trucks. Is that stake pocket spot welded on?
Doug
Yes, the stake pocket is spot welded to the bedside. I had to drill those out to get that piece of junk off the bedside.
I appreciate that!
Doug
