9 members (Hotrod Lincoln, sron48, FAST55, Uncles51, gswbbc, Hanks custodian, 32Fordpuchoptop, Joe W, 1 invisible), 158 guests, and 1 robot.
Topics128,041
Posts1,055,479
Members48,424
#1532649 01/12/2024 2:31 AM
59 Apache 3100
59 Apache 3100
Now that my speedometer finally works........... its off. I switched the stock 3.90 gears for the optional 3.38 gears.
I purchased the brown gear in the picture with 18 teeth. Hoping it would fit a 1959 3 speed ....... it doesn't ( listed as fits 1960 3 speed). It's a tad wider & wont go in all the way.
The catalog I just got shows a blue gear for 3.38 BUT it's also a 20 tooth .... just like my original .
Thoughts???? headscratch
1959 3100, original 235/3 on the tree w/overdrive. Carter YF 2100S carb, 205/75/15 w/front sway bar
The ratio of the number of teeth between the drive gear and the driven gear is what matters. You see how it says the 20 tooth is for both the 3.38 and the 4.11? That is because the driven gear is different between them.
How sure are you that the 20 tooth gear you have is correct for the 3.9? It is possible that you need to replace both gears to have it be right.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
59 Apache 3100
59 Apache 3100
Being i'm the 2nd owner of this vehicle, I don't think the previous employees modified it. (it was owned by CA, as a maintenance truck at a state mental hospital)
Also the "stock" one is metal & leads me to believe its a oem product.
I didn't think about the "drive gear" inside, but that makes sense. I need to see if those are available for these 3 speeds.
You'd think the parts suppliers would sell them as a pair.
Thanks for the help!
The standard truck 3 speed of that era used the metal gear which corresponds with the drive gear that is
pressed on the output shaft. Cars used the same transmission with a plastic gear and corresponding drive gear.
I have the car drive gears that I could share. You would have to disassemble the trans to install it.
Send me a PM.
Fred
This info may help you figure out what you need. LINK
The following page of the link may help you sort it out, although the axle ratio may not be listed.
The tire size also factors into it. You may just need to settle for something that's close.
My truck is a 54 with a 4 speed and it has a 20 tooth driven gear and 7 tooth drive gear probably the same tooth count as it came with the 390 rear that year. It might be easier to put the original back in and go with a adapter that I have read about sounds like they are not that expensive and may be worth a look.Check a few posts back I posted about the Speedo gear on the 4 speed and someone replied with a sheet showing the original Speedo options for 1954
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
