2 members (Tinker5, klhansen),
178
Mod | | | Forums66 Topics128,195 Posts1,057,369 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 22 | Can anyone tell me the thickness of the two washers on either side of the universal joint ball oil seal on a 1946 torque tube? The parts book says these are 2 11/32" OD but does not give thickness. This is the seal at the rear of the universal joint ball. | | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | Since the gland nut is threaded, the thickness of the washers does not matter. They are only there to sandwich the rubberized cork seal between them and squeeze it down onto the tube. The idea is to make the seal tight enough to prevent leaks without restricting the sliding movement of the tube as the rear springs flex. Jerry
| | | | | Joined: Sep 2009 Posts: 6,045 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,045 | 100% agree with Jerry's comment about the purpose of the washer.  FWIW, A search through GM Partswiki for GM# 595013, Washer - universal joint ball seal came back in all available Chevy and GMC parts books in that database listed as 2-11/32" OD X 1/16" for all applications.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jun 2008 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 22 | Great, thanks for the help. | | |
