0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
Hi guys,
I have a 1949 GMC FC102 with a 228 engine. Prior to my purchasing the truck, it has a 4 barrel intake manifold and Fenton Headers installed. The engine has had a full overhaul and a 264 3/4” grind cam. The engine has not been run since overhaul or installation of this intake and exhaust manifold set up.
The concern I have is I see very minimal clearance between the intake and exhaust manifolds (see pics). The closest clearance is .016” the other side is .032”.
Should I be concerned with this? Thank you.
Original equipment intake and exhaust manifolds are bolted together to let exhaust heat keep the mixture in the intake uniform by assuring the gas doesn't condense and puddle in the bottom of the intake runners, especially toward both ends of the engine. Your aftermarket (racing) manifolds don't have that provision, so the mixture distribution between cylinders will be all over the map- - - -rich in the middle and lean on both ends. Racing equipment on a street engine is rarely, if ever a good idea. If those manifolds were actually touching each other things would be marginally better, but the gaps you've measured won't make things better, or worse. The aluminum intake on a street engine is also less than desirable. A 4 barrel on a 228 engine doesn't make good nonsense. I'd suggest that you find an original intake and exhaust and a 1 barrel Carter or Zenith carburetor, and do a P.T. Barnum move on someone who thinks he needs those manifolds. Good luck!
