5 members (Otto Skorzeny, Erniegp, Hanks custodian, 2 invisible), 49 guests, and 2 robots.
Topics128,054
Posts1,055,780
#1531688 01/05/2024 12:11 AM
8
nothing beats a try but a failure
8 Offline
After installing new bushings in the cab mount shackles. What procedure would you take to find the resting place for a 54 cab? I wondered about the .76 clearance after reading an adjacent article. Just curious. Without the gas tank and seating I could add weight to the cab but the question still remains.
1955.1 3600 5 window 4 speed all original except the 410 gears.
In the Project Journal
87GN #1531695 01/05/2024 1:19 AM
I don't know how complete the cab was at the factory for that assembly instruction. Given the nature of the rubber bushing shackle, it would settle a touch after adding load. But the critical thing is to get the rear cab shackle set correctly along with the front cab mounts, and the radiator support. After that, if a couple of people pile in (on average heavier today than they would be in the '50s) whatever movement is just what it is.
I would use that 0.76" with a fully assembled cab and let it go at that.
Moving to Paint and Body because it's more on topic there than in GTT.
87GN #1531761 01/05/2024 7:29 PM
Here is how I do it.
Put a piece of 1"X4" between the floor and the frame near each shackle. You don't need the shackle assembled at this point. (A 1"X4" is .75")
This will level the rear of the cab and put it real close to where it will ultimately end up.
Move to the front cab mounts. Make sure the cab mount supports are not rusted out and collapsed. Shim the front of the cab to the proper distance between the cab and the frame.
Go back to the rear of the cab and bolt the shackles on and shim to specs.
The reason I do in this manner is that it your front mounts are out of whack, this will make it impossible to set the rear shackle as they are designed to move around a lot.
