0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 34 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 34 | I have a 1955 second series pickup. The truth of the matter is, that it is a parts truck and nothing fits. I purchased some years back new stock type weather stripping and even though it is in the truck is does not allow the door to sit properly in the frame. I was wondering if there is a non stock type weather stripping that might work better for my application or should I cut back the stock weather stripping to allow the door to close properly. I have installed new door hinges, new door latches and new lock plates. After all this time and hours upon hours of work my passenger side door still looks like it is not closed. Help please.
Pete | | | | | Joined: Oct 2021 Posts: 6,722 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,722 | None of the seals sold today are the correct thickness or the correct foam density. The closest one to the right size is from The Filling Station, I believe. See this thread.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: May 2015 Posts: 11,017 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,017 | Restoration Specialties has a ton of different weatherstrip products. I'm sure they could provide about whatever you need. Helpful folks there. I inquired with them about windlace quite a while back and called today to order some things and they remembered sending me samples.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Remove the door striker and adjust the door at the hinges until the door closes properly. Removing the striker will get the latch out of the equation, simplifying the fitment procedure. Moving the door rearward may give the seal room to compress enough along the front edge to allow the door to close in the door opening. If that does not completely solve the problem, moving the leading edge of the door 1/16" proud of the front fender may be enough to get enough additional space for the seal to compress properly to close the door.
| | | | | Joined: Feb 2023 Posts: 190 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 190 | Sounds like my next step on my 62 C10. . ^^^^^^^
I moved the hinges out on both doors and it made a little difference. Moving them back a smidge might help too .. ðŸ‘ðŸ‘
