9 members (GMCJammer51, Materman, Lightholder's Dad, Ridgeback, Brian Moore, tclederman, jupitor, treegrower, 1 invisible), 189 guests, and 2 robots.
Topics128,080
Posts1,055,952
Members48,430
#1530350 12/23/2023 6:31 PM
Decided to create a new thread rather than tag onto guitplayer. I made it “pretty” but I’d like it to be functional as well. I do not have a 6v battery to connect to for testing, just a 6/12 volt battery charger and it will not work connected to the 6v from the charger. Thought maybe not enough amps? Or the horn doesn’t work. Don’t want to fry it, so what heft of voltage reducer does a horn need? I bought a light duty ones for the heater blower and gas gauge. #2, if it does need to be torn apart, has anyone been successful and share experience for this old girl?
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
37 GC #1530358 12/23/2023 7:01 PM
Your battery charger may not put out anything unless it senses some voltage in the battery it's intended to charge. But you should be able to test using a 12V battery without damaging the horn. Just don't leave it connected very long.
37 GC #1530359 12/23/2023 7:05 PM
Ok, so take this with some salt because I have not rebuilt that particular model. I rebuilt the one shown below last weekend. It was a 6V horn originally that I am running on 12V. From what I have read, it should be fine. By inspection, I agree. For testing purposes, I would not worry about the 12V vs 6V.
This one draws about 7A when it is running. Most of the modern battery chargers have some smarts in them and they won't put out power if they are not connected to a battery. If the horn is functional, its internal resistance is probably too low for the charger.
With that out of the way, step 1 is to see if it is electrically connected inside. Measure resistance from the case at the mounting bolts to the terminal. It should be less than 2-3 Ohms. The one I just did was 0.3 Ohms.
If that measures good, use your jumper cables to connect it to a 12V battery for a quick burst (less than 1/2 second). If it makes noise, it is probably good and ready to go when you get a new battery. If not, then it is likely frozen inside. The reason for the short burst is to not burn it up if it is frozen.
The next step is to open it up and see what went wrong.
The easiest things to check are:
Does the diaphram move smoothly in the coil?
Is the coil open or shorted?
Are the switch contacts clean?
Are the switch terminals connected to the housing/post cleanly?
If those all come back good, then it is probably just out of adjustment.
Based on the ones I have torn down before, my bet is on the diaphram being frozen in the coil or dirty/scorched switch terminals.
Horn
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
37 GC #1530362 12/23/2023 7:28 PM
Kevin, this old charger is dual amp/dual 6/12v with a couple of switches...old school and certainly not smart technology. I'll to the quick bump on 12v to my battery. Thanks for the starting point Fib. Company is headed this way for the holidays so I"ll give an update later. One of the few priorities over the '37 and a patient wife is granddaughters to play with! lol Last ? for the day though, Are you saying, like my starter, the horn will live fine with the 12v conversion I'm doing without a voltage reducer (if indeed it will come alive)?
Larry
37 GC #1530367 12/23/2023 8:13 PM
Yes, it will be a bit louder with 12V but survive fine.
37 GC #1530370 12/23/2023 8:53 PM
back yard wrench turner
I'm using my 6 volt horn on 12 volts. Yes it's louder!
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
37 GC #1530388 12/23/2023 11:08 PM
Had a couple hours before anybody arrived so I went out and played with my horn. It had 2.5 ohms across the terminals but did not make a sound. Took apart, cleaned it up. Contact points looked pretty good but shined up with a points file. Put back together and she is LOUD on 12v. Must’ve just been the dirt and spider webs. Did not even adjust. Plan on using a relay when I do wiring. Thanks guys, happy holidays!
Larry
37 GC #1530415 12/24/2023 3:20 AM
Woo hoo!
