1 members (1 invisible),
119
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,059 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2021 Posts: 98 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 98 | Can you get by with out using the inner fender anti squeak gaskets on the task force trucks. I sprayed my inner fenders with raptor bed liner. I have seen where the gaskets collect moisture and promote rust. | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | You should be good to go with the bed liner without the gaskets (which tend to wear through over time and squeak anyway. That's why they started putting radios in trucks.)
