Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
3 members (Woodcmiami, newtonlr, moparguy), 613 guests, and 1 robot.
Topics126,776
Posts1,039,259
Members48,100
Most Online2,175
Jul 21st, 2025
I would classify this style as I don't know what I'm doing.
The bottom of the left door that had shipping damage ended up not having the proper curve. Had things adjusted best I could but it was not going to look right.
Well carpet, wood, and a scissor jack to the rescue. I had small blocks of wood to stop the bottom from moving too much. Not sure if this would pass the test from the pros here, but it worked for me.
1966 C-10 Step Side
A Project Journal
Hey, I'm no expert, but I say that whatever works is good. I've used similar methods.
Looks to me like you do know what you're doing. thumbs_up
The rest which is a minimal amount can be done with the hinge adjustment. I lost sleep about this sat night and this was the only solution I could come up with. If you zoom in to the bottom of the door it fits perfect now. Very satisfied with how it came out.
1966 C-10 Step Side
A Project Journal
Big Bolt Forum Co-moderator
I saw that method used on the East German Trabant. www.youtube.com/watch?v=V_t4k02oN84
1948 Chevy 2-Ton
Nice!
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.938s Queries: 16 (0.071s) Memory: 0.6128 MB (Peak: 0.6751 MB) Data Comp: Zlib Server Time: 2025-09-22 01:38:03 UTC
Valid HTML 5 and Valid CSS
