1 members (delky), 130 guests, and 3 robots.
Topics128,062
Posts1,055,854
Members48,428
I am looking for a fan blade replacement. I can certainly buy a stock blade but is there a better available that fits. It's for a 235.
Long story short; the replacement engine I was hauling home tipped on its side and bent the blade. I bent it straight but I believe the strength in the metal was compromised and now the edge of blade will hit the radiator at higher revs.
54 Chevy 3100 Deluxe 3 speed on column. Keeping original as possible but changed to 12 volt system.
JB Weld..."I put that stuff on everything"
I think you should find an original fan. These trucks aren't known for having overheating problems so there is no need for an "upgrade" in my opinion.
1950 Chevrolet 3100 (Ol' Roy)
You may be able to reuse the fan blade you have. If you bent it back straight (only once) the metal should still be strong enough so that it won't flop around. Depends on how far it was bent. Unless the bend has kinked the metal, straightening it should work fine. You'd be surprised how much strength steel has even when bent multiple times. Try bending a piece of wire to break it and count how many bends it takes for it to break.
These old fans can get fatigued and throw a blade right through the hood! No, didn't happen to me but it definitely CAN happen. It's probably a good idea to see if your machine shop can magnaflux it or whatever for cracks that are invisible to the eye. Don't know anyone who's done that though.
Tempted to remove the belt driven fan and see how much quieter it is at highway speeds. Stovebolter HRL (Jerry) says it makes a big difference.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
1 Offline
Jerry is right about the noise but if it's put to truck duty it's likley to overheat on hills also in heavy traffic. Even with an electric fan mine will overheat on hills but it's in severe service so I have both mechanical and electric set to come on at 200 deg.
1951 3800 1-ton
In the DITY Gallery
I believe I will need to replace the fan. Yes, it bent rather far back. From all I've gathered, I need an 18". Amazingly, the online part stores that usually come through with most parts do not have 4 bladed fan 18". I'm not sure if one for the 216 engine would fit or be efficient. They have those.
Measure the bolt pattern and the diameter of the fan center hole where it fits on the water pump. The vendors usually provide that info.
AD Addict & Tinkerer
In ‘54 (and ‘55), Chevy changed from a 216 to a 235, but the water pumps are the same, so a 216 fan blade will fit.
Post an ad for a 216 fan and hopefully some ‘Bolter will come to your rescue!
Phil
Project Journals
Stovebolt Gallery Forum
