1 members (keithfielder), 156 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
So I purchased a 235 that checks out to be a 1958 model. Trying to find clutch and pressure plate. Clutch disc measurement is 11" pressure plate has 9 mounting holes. Not having much luck. Found where it was an option from 55-62 but flaps has no listings. What vehicle do I need to look for. Thanks
Riding in the Passing Lane
I see you are close to Springfield, mo. Contact Osark Clutch. They have parts & will rebuild yours.
George
1972 Chevy c10 Cheyenne Super
Thanks George. It looks recently put in just curious why it's so odd? Thinking I'll go with more common set up just threw me off. I have enough unicorns in this truck already.
I may be wrong on this (I was wrong once before). I'm thinking the 9 hole clutch was used before 58. You may have an older flywheel on it.
George
Here is what I found
breezy, can you do me a favor and give me an overall height measurement of your pressure plate.
This what you need?
Well not sure I'll use it but it's ready to go.
Moderator, Electrical Bay
I have an 11 inch pressure plate (removed from a totaled 1954 Corvette), a disc for it and a matching pressure plate. Best combination I've seen in a long time. I also have a couple of smaller pressure plates but if you have 11" I'd get the flywheel resurfaced professionally and I'd use it.
~ Jon
But is it a 9 bolt pressure plate?
Offhand I can't remember. Something in the back of my mind is saying it was 6 bolt. I know the smaller diameter ones were 6...just not certain about the 11 inch. The disc and pressure plate were LUK products...I had to get a different spline count for the T5.
~ Jon
I'm betting 6. That's the strange thing about this one it's 9.
IDK if this helps or not ,but my 57 235 before I got it rolling.
Ram 10.5 clutch 92761 with a 10spline clutch disc
RAM OEM Replacement Clutch Discs D4187
I used a bronze bushing instead of the bearing pictured.
Maybe look for a new flywheel thats more compatible.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
11" clutch in my '55 235 has a six bolt basket.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
I got my clutch for my 54 from a local shop ,it was hard for them to get but I think I found rock auto had them also ,Not even sure if mine is 11 inch as it was a while ago I got it but I will look as the box is still there with the old one .Here is rock autos
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
I guess the heavy duty clutch from the year is the 9 bolt .The ones I see a rock auto are 6 bolt .chev of the 40;s but big bucks
"The Journey"
Follow in the DITY
That's why I'm thinking I'll go with the smaller clutch set up from my other motor. Seems like a unicorn to me. Maybe someone else will need it. I wont get rid of it just because I keep everything!
1 Offline
I have the 9-bolt clutch in my 1-ton. It has a 9-hole, 6V flywheel.
When I had it all apart a year ago last summer I went looking for a 6 hole flywheel, which, unless I found a 54 flywheel, meant changing the starter too. I ordered a flywheel listed for a 55-62 Chev I6 from Summit Racing. Rock Auto's listings were too confusing. What came in the shipment was for a V8. I sent it back and had my existing flywheel resurfaced. The machinist suggested that if I wanted the 6-bolt clutch, "Just redrill the flywheel for that clutch." I put the 9-bolt back in as it was in good shape. I'd had it rebuilt about 2 years before. All is well.
1951 3800 1-ton
In the DITY Gallery
Originally Posted by breezy
This what you need?
Yes! That helps! Thanks!
I have the 9 - bolt clutch on my 47 3600. The 9 - bolt is the heavy-duty clutch. I re-surfaced my flywheel and the pressure plate myself on my Bridgeport rotary table and a cupped stone in the spindle. I do disc brakes the same way. I bought a new clutch disc for my truck. It works perfectly. I'll never wear it out in my lifetime. I would not hesitate to use your 9 - bolt clutch.
1947 3600 Chevy
