2 members (GMCJammer51, RLB), 148 guests, and 1 robot.
Topics128,285
Posts1,058,278
Members48,483
1942 235.
I noticed that connecting rods # 3 and #4 have larger diameter upper oil passages (at the base of the I-beam) than the others; 7/32" vs. 5/32". Does anyone know why this might be?
1942 1-1/2 ton flatbed
All the ones I have on hand step down to a very small spit hole through the rod, no matter what size the bottom of the hole is. Maybe it's just a safety factor to make sure the hole in the rod bearing lines up.
