3 members (GRNHydra, Wally / Montana, Nick in Manitou), 100 guests, and 6 robots.
Topics128,077
Posts1,056,014
Members48,433
#152912 05/25/2007 1:41 PM
I've got a line on what appears to be a 1957 (possibly 55 or 56) 6400. It's got a staight 6 engine. I've not been able to look and see if it has the "captains bars" of the 261 or not. So I'm guessing it is either a 235 or a 261.
If it is a 261, is this the full flow oil engine or not? Any differences between this engine and the 261 they made in 1961?
The valve and push rod covers are painted yellow. Does this mean anything?
It's NOT a newer 6 cylinder, as it has the old motor mounts up front, not on the sides.
Thanks.
Moderator
Moderator
2 Offline
jhaa
A little off topic, but you might check out this auction Monday.
"56" chevy 6400 with hoist for parts.
It should go for scrap value or less.
Let me know if you are going to be there so I don't bid you up. I'm interested just to save it from the crusher.
2-Ton
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Riding in the Passing Lane
It,s almost certain to be a 261. That year did not have the full flow oil filter but did have the full pressure lubrication. That is the basic difference between it & a 61. The yellow paint is probably what someone had handy or thought it looked good.
1972 Chevy c10 Cheyenne Super
#152915 05/25/2007 11:32 PM
Not all 261's have the "Captain Bars".
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
jhaa,
Yellow was supposedly the 261 truck engine color in 1957.
As stated above, the major difference between 57 and 58-62 261s is the by-pass oil filtration in 57 and full-flow oil filtration in 58-62. There are also differences in how the oil passes from the cam ends through the lifter journals to the head/rocker-arm assembly (and a few different parts in these areas).
Just out of interest, does the engine have a PCV system?
Tim
Here's a picture of the engine in question
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
looks to me like a 235 :confused:
GMC: Get More Cash...
1958 GMC
My Webshots photos
3B Offline
Hy guys, The engine "should" be a 261, but I can't tell the difference from a picture, 235s and 261s look the same to me. Yes the engine in the picture does have a p.c.v. system on it. Any chance of posting some casting numbers from the block and head?
My 55 6500 has the 261 and it's yellow with the old "job master" logo still on it.
