1 members (Hotrod Lincoln), 75 guests, and 3 robots.
Topics128,090
Posts1,056,376
Members48,442
#1528134 12/02/2023 12:59 AM
So I'm starting a new adventure and need to know if front cross member is the same from 48-53 ?
1/2 thru 1 ton?
I have searched but can't seem to find an answer.
Here's the listing from the 29-54 parts manual.
The answer to your question is yes. Same from 48-54 1/2-ton thru 2-ton.
Thanks sir. I knew someone here would know the answer.
Now the fab work begins on the spare frame!!
GMC crossmembers are different due to the longer GMC engine. Found that out the hard way once.
Well curious how to tell the difference. Has a chevy engine bolted to it so I can only assume it's chevy.
Here is a post that has pictures of both Chevy and GMC front crossmembers.
Looks like a chevy to me. Thanks fellas.
