1 members (Russ_B_10), 91 guests, and 2 robots.
Topics128,050
Posts1,055,643
#1528294 12/03/2023 6:36 PM
There’s probably something in this forum about this, but it takes forever to search through the search results. Are any of the new door hinges any good? The posts I found are old, so maybe newer repro hinges are better? Do any suppliers have new hinges that are decent? Or are you aware of anyone that will rebuild old hinges properly?
Mike Barnes
1950 GMC 1-ton pickup
50GMC253 #1528332 12/03/2023 11:44 PM
I have not used new hinges but hear they are not that good someone that experienced this May correct me .I have rebuild my hinges and they are not to hard and parts were available even the plates can be purchased or what I did is made one from the tech tip .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Moderator, Electrical Bay
The reproduction hinges I bought had to be bent, adjusted, twisted, etc...multiple times. And they'll never be as good as original. You'll need some specialty tools to do this and some experience working with thick metal.
~ Jon
I know of one guy in Oregon that rebuilds them. I personally haven't tried him but he seems pretty knowledgeable about rebuilding parts on these old trucks. He's connected with the Filling Station in Lebanon, Oregon. Name of Jerry Kassis. He also does videos on YouTube showing how to rebuild them if you want to try it yourself. "1947-1954 Chevrolet Pickup Door Hinge Restoration" is the YouTube to look up. This is his contact info but he won't answer his phone; leave a message; [email protected] or call me at (541) 405-8286.
Stewart2
1955.1 3100
Both Owner and P/U have lots of miles, lots of history and need LOTS of TLC
Jack of several trades and experiences; Master of none
50GMC253 #1528402 12/04/2023 12:10 PM
Thanks guys. I was able to drive the pins out fairly easily so I’ll go with the pin and bushing method. I have no drill press but am sure a local machine shop will drill the arms for bushings.
Mike Barnes
If I remember correctly the kit comes with a little bigger pin so you have two choices if original not that worn you can just replace the pin or use the bushings if worn past the size of the new pin .I just put new pins .
"The Journey"
Follow in the DITY
Just FYI that Jerry Kassis restored my door hinges and vent windows... pictures enclosed.
1952 Chevy 3100
Thanks all. Jerry Kassis has agreed to rebuild them for me. After the major pain to remove doors and replace the seals and window channels, I don’t want to have any hinge problems!
Mike Barnes
50GMC253 #1533269 01/17/2024 10:45 PM
I received my rebuilt hinges. Jerry does fantastic work. Highly recommended!
Mike Barnes
