3 members (KCMongo, HelmutVonSchet, 59 fleet), 90 guests, and 0 robots.
Topics128,049
Posts1,055,679
#1527445 11/26/2023 9:10 PM
This is probably an obvious question but will a SBC Chevy mid plate work on a 292 since they are the same bell housing?
mick53 #1527446 11/26/2023 9:17 PM
What's a "mid plate"? That's a new one on me!
mick53 #1527454 11/26/2023 9:45 PM
Are you asking about the separator plate to protect the engine and trans from each other in case of catastrophic failure?
Something like this?
https://www.summitracing.com/parts/qti-rm-6011/make/chevrolet
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
mick53 #1527472 11/27/2023 12:15 AM
https://www.summitracing.com/parts/cee-4031 I'm sorry, engine mid plate for mounting into the chassis. My terminology isn't very good.
mick53 #1527480 11/27/2023 1:15 AM
As long as the bellhousing bolts line up, it seems like it should work to me.
mick53 #1527589 11/27/2023 7:14 PM
Do like the race car dudes. Make your own. .250' 6061. Seem to have no problem holding those 2000 hp plus hemi's in the car. This particular one is a no-no these days. The hole is only supposed to be as big as the crank flange, not as big as the clutch. Made it easier to service that clutch, though.
mick53 #1527612 11/27/2023 9:40 PM
Does the added thickness give you any issues with the input shaft on the transmission? Or as long as the pilot bushing still has some enagement it is ok?
mick53 #1527614 11/27/2023 10:02 PM
Use a custom made pilot bushing- - - -add the thickness of the plate to the depth. That kit that was illustrated already has a shim for spacing the flywheel back the right distance. There's a similar adapter available to fit a BOP bolt pattern automatic transmission to a Chevy block. I've got one stashed away somewhere that mates up a big block Ford bellhousing to a GM bolt pattern
Fibonachu #1527635 11/28/2023 1:13 AM
It's all custom stuff. Example, adding a T5 transmission usually requires an adapter plate to move the trans away from the engine on the early Chevy pickup bellhousings. Using a motor plate might allow you to use a thinner adapter plate. Maybe even fit more clutch in there. When I adapted the Ferd 302 and toploader, I had to machine down bellhousing parts to get proper engagement. In the dragster pictures I posted, it had a 2 speed in it, but ultimately used to be and was restored to a direct drive. Which is a whole different animal for engagement and such. Like Jerry says, you find the stuff that wll make it work, like a different pilot bearing.
mick53 #1527677 11/28/2023 4:26 PM
Mark, it looks like the innovative tinkerer who "makes things work" is becoming an endangered species. If somebody, somewhere can't design a "kit" on a computer that allows a no-talent wrench jockey to bolt stuff together with a mindless rote procedure and some printed instructions, then "It can't be done"! It usually involves a million dollars' worth of of CNC equipment and a 3-axis printer to make the kit, too!
mick53 #1527690 11/28/2023 5:10 PM
We have kind of gotten off topic here.
My read of the above information is that yes, Mick53 should be able to use the SBC midplate because the bellhousing is the same?
All of the extra for for a midplate will need to be done, but his application is already custom enough to expect that.
Agreement?
mick53 #1527702 11/28/2023 6:40 PM
Options are always good.
Fibonachu, agreed.
Fibonachu #1527727 11/28/2023 9:56 PM
Agreement?
Thank you for answering my question. Could I make this? Sure I have a mill. To buy a piece of .090" steel just big enough to make this is $55.91 plus tax. To make it out .250" 6061 aluminum it's $136.44 plus tax. I still have to drive an hour each way to pick it up. That's $35 in fuel in my F250 SD. I didn't want to justify using it or making it. Just trying to ask a simple question without getting attacked for some strange reason. Thank you for your time.
mick53 #1527754 11/29/2023 1:56 AM
mick 53, I certainly hope you don't take any of that as an attack. Seeing all that you have fabricated so far, I had mentioned making your own motor plate as it seemed par for the course with what you have done to date. In no way would I tell you what or how to build your project. And I don't speak for Jerry, but I don't believe he directed it at you but just a comment in general. You certainly don't classify as someone who is a "bolt on" guy, not that there is anything wrong with that. People are capable of different things at different levels.
The amount of time, fabrication skills, effort and level of precision you have put into your project so far still blows me away!!
mick53 #1527798 11/29/2023 3:42 PM
Crusty Old Sarge
Crusty Old Sarge
I have been following mick53's build for a long while. He has put a lot of time and energy into the build, the plan is solid and very unique. Many of the the mods he done are custom and one off, he is more than capable of finishing this project. I don't believe he posts here just for the glory of "Posting", I believe he genuinely wants to share the journey with us. I for one am waiting to see what he will do next. thumbs_up thumbs_up
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
mick53 #1527802 11/29/2023 4:08 PM
I wasn't my intention to put anyone's opinion down. It just seems that certain people always put me down for spending too much or taking too long or it's just a dumb idea. All of those could be true. I'm not young and I'm not rich or healthy. I have more titanium in me than a ProMod thanks to the US government. I move a little slow. There is a real chance I will never get this done. For me it's the journey not the destination. I don't have anyone to show it off to anyway. I'll just have to build another one. A lot of stuff I post on other sites to avoid the grief. I don't need the drama. Let's get back to building with crazy ideas. It's the HiPo forum. This was my first forum and I still consider it the best. Don't worry about me I'll be fine. Thank you for your time and all the support and advice I get from 99% of you.
mick53 #1527805 11/29/2023 4:58 PM
62401
No drama...
Get back to building with crazy ideas ...
Its the HiPo forum ...
Indeed!!
(The no-talent wrench jockey Jerry was referring to. smile )
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
mick53 #1527834 11/29/2023 8:20 PM
Former Workshop Owner
Quote
For $72.99? That's a bargain. Even if the material was free I wouldn't build it and I have a shop full of mills etc. Probably just like you, my time is more important to me. Now if it were $172.99 I might reconsider.
Just my 2 cents.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
mick53 #1528116 12/01/2023 9:04 PM
You can absolutely use a mid plate for a small block. May require a little trimming here and there to fit the chassis but yes you can. The bigger challenge is designing and fabricating the front plate. I have a front plate but it was made by Ronnie Cox a really long time ago when he owned Stovebolt Engine Company. It was sold as part of a two piece timing gear cover that was cast a little shorter for use with the front plate.
That being said, I suppose you could make up either two plates that would attach to the two bosses on the front of the block (only on a 292), or a single plate with a cut out on the bottom to clear the oil pan, that would essentially clear the stock timing cover.
Mike
mick53 #1528190 12/02/2023 4:01 PM
Many dragsters run a TORQUE Plate and NO front motor mounts, just a piece of split tubing resting on the chassis tubing. This prevents chassis twist from being transferred into the engine block. Our sprint car runs this set up with hose clamps on the front mounts.
Evan
