7 members (Wayne67vert, cmayna, Gdads51, Otto Skorzeny, klhansen, 55shaker, Stewart2),
169
Mod | | | Forums66 Topics128,165 Posts1,057,011 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Just saw this on ebay and since I know nothing about this subject I am curious if this is an overdrive for a big bolt? http://cgi.ebay.com/ebaymotors/spic...733QQssPageNameZWDVWQQrdZ1QQcmdZViewItem A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Found this neat link on the brownie transmissions. http://www.6066gmcguy.org/spicer-5831-b.htm A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | here is one I have for sale http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=29;t=003005 | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Which letter suffix do you have on that tranny? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | None. It is a 0.73 overdrive. Grigg | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Ah... I see by the chart on that link I posted above that there are three tranys that have the .73 OD, the others are ones like yours without a letter suffix and the 5831 A and the 5831 E. I wonder how hard it would be to find the linkage, shaft, shifters, and mounting bracket for yours. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The driveshafts are no problem. The mounting stuff can be made from scratch. I have been looking at shifters on cab over trucks, and I think one could be used for the 5831. Or an original could be found in a junk yard, but they are a little hard to find. I have also considered making one. Or perhaps the shift tower from a regular 3 speed floor shift transmission could be used if the shift rails were extended, then attach the linkage to them to go back to the spicer.
Grigg | | | | | Joined: May 2005 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 41 | Grigg, I think I have a similar unit on my GMC with the tandem tag axle. Do these units make a big difference in mileage or top speed. The truck is a '52 or '53 with a 302.
Terry Wofford '52 GMC 3 1/2 Ton '51 GMC 2 1/2 Ton '53 GMC 1 1/2 Ton '53 Chevy 2Ton "If it ain't broke, well give me the keys and I'll be right back!"
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | It depends on what ratios you have as to the difference in top speed.
Most have either a .85 or .73 overdrive, they help with top speed.
Some only have direct and two slower gears.
The 6066 link posted above has this info. And if you don't find what you need there I have a good bit of information on them, including the larger sizes.
Grigg | | |
