1 members (ronsway), 185 guests, and 2 robots.
Topics128,167
Posts1,057,019
Members48,458
Big Bolt Forum Co-moderator
Just saw this on ebay and since I know nothing about this subject I am curious if this is an overdrive for a big bolt?
http://cgi.ebay.com/ebaymotors/spic...733QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
1948 Chevy 2-Ton
Found this neat link on the brownie transmissions.
http://www.6066gmcguy.org/spicer-5831-b.htm
1948 Chevy 2-Ton
here is one I have for sale
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=29;t=003005
•1952 Chevrolet 3800 pickup
---All pictures---
Which letter suffix do you have on that tranny?
1948 Chevy 2-Ton
None.
It is a 0.73 overdrive.
Grigg
---All pictures---
Ah... I see by the chart on that link I posted above that there are three tranys that have the .73 OD, the others are ones like yours without a letter suffix and the 5831 A and the 5831 E.
I wonder how hard it would be to find the linkage, shaft, shifters, and mounting bracket for yours.
1948 Chevy 2-Ton
The driveshafts are no problem.
The mounting stuff can be made from scratch.
I have been looking at shifters on cab over trucks, and I think one could be used for the 5831. Or an original could be found in a junk yard, but they are a little hard to find. I have also considered making one. Or perhaps the shift tower from a regular 3 speed floor shift transmission could be used if the shift rails were extended, then attach the linkage to them to go back to the spicer.
Grigg
---All pictures---
Grigg, I think I have a similar unit on my GMC with the tandem tag axle. Do these units make a big difference in mileage or top speed. The truck is a '52 or '53 with a 302.
Terry Wofford
'52 GMC 3 1/2 Ton
'51 GMC 2 1/2 Ton
'53 GMC 1 1/2 Ton
'53 Chevy 2Ton
"If it ain't broke, well give me the keys and I'll be right back!"
It depends on what ratios you have as to the difference in top speed.
Most have either a .85 or .73 overdrive, they help with top speed.
Some only have direct and two slower gears.
The 6066 link posted above has this info. And if you don't find what you need there I have a good bit of information on them, including the larger sizes.
Grigg
---All pictures---
