8 members (2-Ton, HandyAndy, Peggy M, Otto Skorzeny, DadsFirstPickup, DES57, Jman, Ponchogl), 103 guests, and 1 robot.
Topics128,102
Posts1,056,532
Members48,448
#1527946 11/30/2023 6:10 PM
After much trial and error I decided to jettison my repop hood springs. I could not get the trailing edge of the hood to conform with the cowl no matter what I tried, tech tip followed. I also noticed that I hid to push the hood all the way down to close - those stiff new reproduction springs seemed to be fighting me all the way down.
For $25 I acquired an original pair of spring support assemblies. I did a “trigger pull” comparison-
New springs: 21#
Original springs: 15#
Old/original springs installed. The hood will no longer hold itself up in mid-travel, ( with repop springs it stiffly held at any level) , but when nearly all the way up it seems to reach a designated spring position and stabilizes. Stays open just fine. I have a feeling that is more like the designed function. The really good part –- the hood to cowl match is the same as when I had the springs out of the equation.
Put a lot of time into that hood. Today is a good day.
Waveski #1527957 11/30/2023 7:21 PM
Original springs will only hold the hood up in the most upright position where they sort of cam over.
Glad you finally got it to work right.
Waveski #1527969 11/30/2023 8:20 PM
(… they sort of cam over.)
That makes sense, and you said it better than I.
Thanks.
