1 members (53 green 1- ton), 110 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#1525809 11/13/2023 5:17 PM
As previously posted, I have been trying to improve the fit of the hood on my ‘54 3100.
I removed it from the truck, adjusted it by placing washers under the center piece that connects the two stiffening frames as per a tech tip , filled and faired the dent that I managed to cause while doing that adjustment (that’s another story), loosened the fasteners that secure the hinge assemblies to the cab , and re-mounted the hood.
And now - for some perverse reason - the back end of the hood does not want to go all the way down! This was not an issue before I took the hood off the truck.
WHAT AM I DOING WRONG???
Last edited by Peggy M; 11/28/2023 6:04 PM. Reason: added less offense word in the title
Waveski #1525818 11/13/2023 6:09 PM
Did you follow the hood adjustment procedure? It will usually give you a spot on installment.
Waveski #1525829 11/13/2023 6:59 PM
Yes.
Since my initial post I tried removing the springs from the equation- and most of my fitting problems disappeared.
–- I should have mentioned in my first post that my hinges are repop. –-
About a week ago I posted a piece about a heavy duty ‘53 pickup owned by a friend of mine. (Sighting Network sub forum)
In the course of looking over that nice old survivor I took a close look at the hood springs. They appeared to have less mass than my after market springs, and the resistance to closing was noticeably lighter.
Conclusion: My new springs are too stiff. I think I will contact some boneyards looking for originals.
Thoughts?
Waveski #1525837 11/13/2023 7:40 PM
Are the hood hinge parts universal ’47 through ’55 1st series?
Waveski #1525843 11/13/2023 8:28 PM
Insomniac
Insomniac
Yes, the springs were a headache for me - any play in the hinges at all are an issue. I took the springs off and now use a hood prop instead.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Waveski #1525901 11/14/2023 1:01 AM
You are missing a step in The Procedure somewhere. PM me. I can walk you through it.
Waveski #1525914 11/14/2023 2:22 AM
Gord - I am considering the hood prop option.
Carl - I will be occupied all day tomorrow, in fact I am playing in an end of season wrap-up golf tournament- I plan to go in style driving my ‘54 to the golf course. The hood is not perfectly fit , but it is much improved albeit without springs. I will open a p.m. line of communication later in the week; hopefully you can help me with further improvements.
Thank you for that generous offer.
I wonder how many Stovebolts are out there without hood springs. I swear my repops are too strong.
Waveski #1525927 11/14/2023 4:17 AM
As long as the springs are the correct length and attached to the original location on the firewall, the strength of the spring won't matter.
I have a pretty good idea what you need to do. PM me when you're ready.
Waveski #1527696 11/28/2023 5:51 PM
Update:
My new/old spring assemblies arrived. I lubricated them , clamped each in a vice , worked them loose then applied a scale.
The originals required 14 - 15# of tension to initiate motion.
The repops required 20 - 21# to initiate motion. HUGE difference on a percentile basis.
Today is the last day of a nasty cold streak here at 43 north. 12 degrees f. at dawn this morning. I probably will not install the original spring assemblies till tomorrow.
My hood to cowl match is presently good. I have followed the tech tip instructions completely - except for the final step which is installing the spring supports. I am cautiously optimistic that the new/old springs will allow the hood to close nicely- unlike the stiffer repops.
We’ll see …
Waveski #1527703 11/28/2023 6:41 PM
7
7 Online: Content
On my '57 LCF, I actually tightened the tension on the hood springs in order for them to hold the hood open all the way. It didn't alter the fit of the hood at all. I know we are talking about 2 different animals, just thought I would add my experience to the equation.
Waveski #1527708 11/28/2023 7:34 PM
Again, we’ll find out soon.
On a side note , someone edited my thread title. I had typed a Beetle Bailey cartoon style “cuss word” using entirely random punctuation marks ; that has been replaced with “blasted”.
Well I’ll be a @#%**Â¥!
Waveski #1527725 11/28/2023 9:54 PM
Authorized Pest
Authorized Pest
You bet I did. laalaa If you don't like "blasted," you can change it to something else. One of us can "re-title" the rest of the posts in this thread.
~ Peggy M
1949 Chevrolet 3804
Waveski #1527773 11/29/2023 4:55 AM
Maybe “BLANKETY-BLANK” would be appropriate, since blasted implies a paint removal method. 😉
Waveski #1527774 11/29/2023 5:42 AM
What’s so bad about “a monkey’s uncle” ?
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
Authorized Pest
Authorized Pest
Originally Posted by klhansen
... blasted implies a paint removal method. 😉
I figured that was "click bait." laalaa
~ Peggy M
1949 Chevrolet 3804
Waveski #1527954 11/30/2023 7:05 PM
Resolution of the problem posted HERE.
Locking this thread down.
