6 members (GRNHydra, Greg_H, dunfire, Ponchogl, TPR57C, stlcardinalsguy), 136 guests, and 1 robot.
Topics128,030
Posts1,055,430
Members48,422
#1521757 10/14/2023 12:28 AM
So I'm a little confused. Read through the tech tip to use a 12 boot generator for upgrade. Everything makes sense except the 12 volt coil. If you install a ballast in line to coil does that not reduce the power? I would think you would retain your 6 volt coil. I've also read most coils are 6 volt anyway. Some just have a ballast from the factory. I'm assuming those are 12 volt systems. I have everything from a 57 so it would be pretty easy except for the fuel gauge. Thanks for any advice.
breezy #1521768 10/14/2023 1:37 AM
Riding in the Passing Lane
I have used 6 volt coils on 12 volts with the resister but it is better to use a12 volt coil designed for use with the resister. If the resistance in the windings are not correct it may burn the points or cause a weak spark. If you have it all from the 57 it will be great.
George
1972 Chevy c10 Cheyenne Super
Thanks George
breezy #1527542 11/27/2023 3:18 PM
"12 volt" coils designed for use with a resistor actually need about 9.5 volts to operate properly, not the 7.5V that a "6 volt" coil sees when a 6V generator is running against a fully charged battery. Use the right part for the setup- - - -.
Thanks Jerry
I have the coil from the 57. Not sure if 57 had a resistor or not.
Condenser needs changed also I'm just presuming?
breezy #1527553 11/27/2023 4:48 PM
Midyear 55-up systems were all 12 volt, with resistors. The same coil was used all the way to the mid-1970s when HEI was introduced. Early 1970s ignition systems used a nickel-chrome resistance wire about 10 feet long between the ignition switch and the coil that doubled back on itself inside the wiring harness instead of a ceramic resistor- - - -same coil works from 55 to the mid-70s.
Buy one of Jon G's improved condensers, instead of the offshore made junk that's usually bad right out of the box.
breezy #1527554 11/27/2023 4:53 PM
The 57 used a resister in the circuit to the coil. It is a ceramic part that was located on the firewall near the regulator & horn relay.
George
Kinda confused me there. So I need a ceramic resistor?
And can I use the condenser from the 57?
Sorry you were posting while I typed. Ok resistor is needed.
breezy #1527559 11/27/2023 5:42 PM
Also use a 55-up foot start switch with the small side terminal on it to bypass the resistor during starting. That puts full battery voltage to the coil to assure a hot spark with the load of the starter on the battery. Rock Auto sells the correct switch, but they call it a "solenoid" for some reason!
www.rockauto.com/en/moreinfo.php?
breezy #1527560 11/27/2023 5:46 PM
Got it. Now how is that wired up?
breezy #1527561 11/27/2023 5:51 PM
A wire from the small terminal goes to the + terminal of the coil, downstream of the resistor. When the starter is engaged, full battery voltage is supplied to the coil, bypassing the resistor. The load of the starter running drops battery voltage down to a bit over 9 volts- - - -which is what the coil was designed to run. Sneaky, huh?
A word of caution- - - -with the bypass wire connected, the engine can start and run with the ignition switch turned off when the foot switch is engaged, unless a different ignition switch with an "IGN 2" terminal is installed. That's a wiring diagram change that was incorporated into the 12V electrical system that most folks don't know about.
So is that an original type set up or something you figured out?
breezy #1527565 11/27/2023 5:57 PM
It's all original- - - -beginning with the mid year 1955 swap to a 12V electrical system.
Cool. You never really answered about the condenser, but according to napa book they are the same. Any input?
breezy #1527570 11/27/2023 6:12 PM
Strongly recommend one of Jon G's solid state condensers:
https://www.stovebolt.com/ubbthread...native-condenser-update.html#Post1388813
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Ok
breezy #1527573 11/27/2023 6:18 PM
I recommended using Jon G's condenser several posts back. No matter what brand name is on the box, all the condensers available these days are coming from the same bunch of 3rd. world slave labor sweatshops, and most of them are junk.
"Buy one of Jon G's improved condensers, instead of the offshore made junk that's usually bad right out of the box."
breezy #1527579 11/27/2023 6:30 PM
Sorry to bother you but does this look correct ?
Can I use the original wire going to amp meter from voltage regulator? And if so which wire is it? Battery wire I'm assuming.
breezy #1527583 11/27/2023 6:55 PM
Sir Searchalot
Sir Searchalot
To clarify: IF I read the caution correctly...........The ign 1 and ign 2 were used with electromagnetic solenoids and a "R" terminal. You have a foot switch with side terminal. That terminal will be dead when you lift your foot. Motor may fire but will die when foot is lifted. Your original ignition switch is OK.
breezy #1527585 11/27/2023 6:59 PM
Send me a PM with your email address. I'll be glad to draw up a more professional-looking circuit diagram that will be easier to follow. That one is technically correct, but it leaves a lot of room to make some expensive mistakes. Yes, the "BAT" wire at the regulator goes to the downstream side of the alternator. It's possible to connect the "ARM" wire and the BAT wire together and use the original generator wiring harness with your alternator conversion, but I'd suggest running a new 8 gauge wire from the alternator output stud to the ammeter instead.
What's a "food" switch? I've seen engines run enough on the bypass circuit during a compression test to amputate fingers with the fan belt. Blood also makes parts rust.
breezy #1527643 11/28/2023 2:00 AM
Sir Searchalot
Sir Searchalot
This diagram incorporates the original 1950 wiring diagram somewhat and mixes in alternator wiring. There are, of course, many more wires in the truck but these are the ones you are asking about. Don't know what all has been added or upgraded to your wiring or truck. You may want to add more fuses and/or use terminal blocks for some wiring. This assumes you have a Delco 10si alternator and want to wire as "3 wire" configuration. No horn relay used on 1950. Can't think of anything from a 57 that won't "work" but advise what 57 parts you are using.
This is the basic hook-up shown for reference. Use your magnify feature to read.
A wiring diagram is not meant to show a person exactly how each wire is attached. Sometimes there are too many wires on a terminal or it is better for routing to do this or that. You can splice, use a terminal block or a terminal on a component to join wires electrically. However it is important to accomplish the exact circuits per the diagram. Be sure you get the same circuit flow as the diagram. Wire sizes are determined per load.
To exclude a "run on" condition reported by some, if you are using the original ignition switch, advise how many terminals it has and then I will suggest some wiring....describe whatever ignition switch you have.
It's good you are asking questions if not sure about wiring. Don't try to figure out how to use or incorporate old wiring circuits. You can snip both ends off of something and use the actual wire if it's in good condition. Some wires are just relocated simply. Colors do not matter. Nothing is hard to trace on a good old AD truck.
You need to look at the tech tip section, under "12V conversion but with alternator" and you will see the basics we are discussing.. Read that, it's a good overview of what all you need to do.
breezy #1527679 11/28/2023 4:30 PM
You keep referring to a condenser while working on the coil. Is this condenser the one mounted inside the dist. with the ign. points or is it mounted on the coil bracket? If it is mounted on the coil bracket it is a radio suppressor & is not needed. The one inside the dist. works with the ign. system. If it fails thats were you set.
George
Points condenser.
George
Plan was to use 12 volt generator from 57. After further research I have decided to just go with an alternator. Thanks for all the help I will review the technical tips.
breezy #1527685 11/28/2023 4:50 PM
Sir Searchalot
Sir Searchalot
Click
You are doing the right thing.
That's the one. I'll get it from the napa store. Worked there for years. They treat me really well.
