3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#1527240 11/25/2023 11:55 AM
Simple design. Allows me to store bed up over frame for compact storage. VIDEO LINK
AD Addict & Tinkerer
Great idea Jay, I’ll be building and using that soon!
Phil
Project Journals
Stovebolt Gallery Forum
Best plans of mice and men . . . .
The lift arms were in the way of setting it on the dolly as designed so I had to turn the dolly 90 degrees. Not being satisfied, I lifted the bed from ABOVE using heavy duty ratchet straps and turned the dolly under the bed the way I had intended. So now it’s oriented correctly for easier movement in the shop when supported over the frame.
I was planning on using an engine lift to remove the bed, raising the lower cross bar so the lifts legs could slide under.
Phil
Project Journals
I did the same, but out of steel, when I was doing paint and body on my dually bed. Mostly a quickie weld up job out of scrap.
