5 members (37 GC, Dusty53, sron48, Vice-Grip, Otto Skorzeny), 130 guests, and 0 robots.
Topics128,114
Posts1,056,613
Members48,450
#1526947 11/22/2023 3:52 PM
Originally the brake line from the lower cylinder to the upper was on top of the axle tube and has some tight bends. I made a new line with less bends and have it going under the axle.
Does anyone see any issues with the new line placement? It does not interfere with any moving parts.
7
7 Online: Content
Other than possibly having to spend a few extra seconds when bleeding them, I don't think you'll have any problems. Looks real good!
Is there a reason the replacement line can't be installed with the arc on top? I'd wonder about air getting trapped below the axle centerline the way it's routed now. Probably not a serious concern, though.
7
7 Online: Content
The original cross-over tube had some VERY tight radii, I know I couldn't copy it with any hand benders. I didn't have to replace those lines. I didn't have to use any power bleeding for my truck, DougH6100 has the same basic set-up as mine, should bleed OK. Looking at his picture does show that the port on the cylinders looks to be straight across the axle, I guess the line could go over the top just as easy.
I decided to go under thinking air might get trapped at the top of the bend.
