2 members (kbenz, Gib70), 166 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
Moderator, Great Lakes Bolters
1 Offline
What are people doing for a heater core when installing a V8 in their AD trucks? I would like to utilize the original heater but have read that the original heater cores can't hold up to the additional water pressure. Even Classic Parts now calls out in their catalog "Not for use with modern upgrades over 4# radiator pressure caps" I believe the small block chevys are running over 10# caps for pressure. (I am not able to spend the money on a new system, such as Classic/Vintage Air, at this time...)
Thanks!!
--Tom
Just about any radiator shop worthy of the name can install a core rated for the right pressure in an original housing- - - - -or at least that's what used to be done.
Tom, A quick check of Jim Carter offered products shows the following new replacement heater cores that are compatible with modern engine higher pressures. Not sure which type heater you have, Recirculating or Fresh Air? Both aren't cheap, but much lower cost than a higher end full system. One note on the core for the Fresh Air replacement - there may be an issue with 1953-55.1 (1st Series) heaters so it would be worth a call to Jim Carter's store to ask for details before ordering.
Recirculating round heater core
Fresh Air rectangular core
~ Dan
1951 Chevy 3 window 3100
1 Offline
Thank you, Jerry, for the advice. I fear most of the quality radiator and exhaust shops in my area have gone away. I tried getting a simple bend made up on an exhaust pipe a couple weeks ago and had to go to several places before I finally found a Midas shop to do it. Even then it took some convincing and they charged a pretty penny for it.
-Tom
1 Offline
Thank you, Dan! I usually check all the usual KC parts places, but failed to see this offering from Jim Carter. I'll give them a shout.
Thanks again!
-Tom
My heater is the fresh air type, rectangular core, and my radiator shop replaced the core (leaking) with one that is okay for modern engine pressures but it was pricy.
1949/50 3600 Project
Follow in Project Journals
7
7 Offline
Hey Tom, there is a custom exhaust shop in my area, I know it isn't convenient for you but a least another option. Kitleys Custom Exhaust, Stockbridge, Michigan. There were at least 4 radiator shops in Ann Arbor/Ypsilanti 20 years ago, all are gone now. I don't know of any current shops.
Sir Searchalot
Sir Searchalot
Moderator, Electrical Bay
I just bought a roll of 1/2 inch copper tubing (flexible) and wound it around a coffee can leaving about 1/4 to 3/8 inch between rows and then repeated the same for another row leaving about 5 inches to be bent and sent through the firewall. You could do the same basic thing if you needed a square or rectangular shape, however mine was round. It generated plenty of heat and only cost me about $30. There's no way you will blow it out...copper plumbing withstands plenty of pressure. Good luck!
~ Jon
