4 members (Otto Skorzeny, dt235sd, Lightholder's Dad, 1 invisible), 60 guests, and 3 robots.
Topics128,180
Posts1,057,149
Members48,464
#1526871 11/21/2023 11:55 PM
I am thinking on using a 47-48 fuel tank and I would like to use a filler that mounts flush to the bedside. I don't think there would be any problem with fuel sloshing out once the cap is on because it's non vented. I will vent the tank and use a roll over valve for safety. Filling it might be a problem, do you think the pump will kick out before fuel sloshes out. Looks like the filler pipe in the tank is level with the ground. Happy Thanksgiving
The original 47-48 filler neck came through a hole in the bedside and exited uphill a bit. I would go with that setup.
