2 members (cmayna, Gray_Ghost),
168
0
Mod | | | Forums66 Topics128,114 Posts1,056,613 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2023 Posts: 118 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 118 | We are rebuilding a sm318 transmission and also rebuilding the torque tube Oakie bushing at the same time. We found a supplier who sells the best #5151 torque tube gaskets. Olson's Gaskets 360 871 1207 Sandy is the owner. Just fyi
1950 chevy shortbed 3100, 216 with a 3 on the tree.
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | What makes these gaskets the best? (No sarcasm, legitimate curiousity) | | | | | Joined: Jan 2023 Posts: 118 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 118 |
| | | | | Joined: May 2015 Posts: 11,109 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,109 |
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Those gaskets are very important- - - -they are stacked up to adjust the tension on the torque tube pivot ball. Too tight and the ball wears and/or galls, too loose and there's a grease leak at the pivot point. Jerry
