1 members (Bisbee),
132
Mod | | | Forums66 Topics128,089 Posts1,056,437 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 22 'Bolter | | 'Bolter Joined: May 2010 Posts: 22 | I am having trouble locating Speedometer Shop in Riverside California .... anyone have contact info for them?
| | | | | Joined: May 2015 Posts: 11,099 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,099 | Moved your post here so it gets better visibility.
Can't find a place called "Speedometer Shop" but here's a business near Riverside that appears to be a speedo repair shop. Found using Google Maps.
All GM Speedometer Repair 993 W Valley Blvd #204 Bloomington, CA 92316 Phone: (951) 536-7862
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2010 Posts: 22 'Bolter | | 'Bolter Joined: May 2010 Posts: 22 | Thank you Kevin! I'll check 'em out and report back.
Haasman | | | | | Joined: Jan 2002 Posts: 2,841 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,841 | My local speedometer shop highly recommends Deluxe Speedometer in Denver to work on old Chevy / GMC truck speedometers.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: May 2015 Posts: 11,099 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,099 | I bought a remanned speedo from Jim Carter. It looks new, but I haven't installed it yet. I believe they mentioned they had a guy in-house that does them - or maybe they just said "our guy" meaning an outside shop.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2023 Posts: 118 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 118 | Try Sam Simone in Washington state.Sam is on Facebook
1950 chevy shortbed 3100, 216 with a 3 on the tree.
| | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | I bought a remanned speedo from Jim Carter. It looks new, but I haven't installed it yet. I believe they mentioned they had a guy in-house that does them - or maybe they just said "our guy" meaning an outside shop. Not sure if it's in house or not, had one repaired a year or so ago. Works great. Also sold them a couple spare cores I had kicking around.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | |
