2 members (tclederman, greenie-reddy), 150 guests, and 0 robots.
Topics128,109
Posts1,056,266
Members48,439
thinking thinking
In the process of removing the trans, I bought the new spring and cap for the shifter base on top of the Muncie SM 420 . I somewhat remember someone telling me to push down and rotate 1/16 th of a turn on the “cap” or the shifter rod or? Brain fade seems like it is coming around more often! Thanks
pdlighting,
Take a read through this older thread on the subject. Gives an in-depth run down on how to remove the cap (the metal dome shaped piece that the shift handle protrudes up through in the shift tower). wink
Lots of pictures as well as info on the original GM tool and how to fab up a contemporary substitute.
Dan
~ Dan
1951 Chevy 3 window 3100
H Online: Content
All I've ever needed was a pair of channellock pliers. The shift lever and cap is spring loaded, so you'll need to soak the area around the cap with penetrating oil like PB blaster to break up any rust, then push down on the cap and turn it slightly CCW to disengage it from the lock pins. Then pull the shifter and cap straight up.
Thank you for the link and the directions. 😀
1 Offline
Ive never needed more than my fingers to unlock it. Maybe that's why it transfers so much noise in 3rd gear.
1951 3800 1-ton
In the DITY Gallery
Moderated by  Dusty53
