2 members (78buckshot, 1 invisible), 390 guests, and 5 robots.
Topics128,162
Posts1,057,042
Members48,463
Hi friends!
I can't find brake shoes, springs and brake cylinders for my 1949 4100 dump truck. Will parts from a 3600 fit?(local supplier has them).
where can I find these parts?
Would it be wise to install disc brakes?
Please help. Thank you
No, 3/4 ton parts won't fit.
Check your shop manual for the sizes of the brakes and you can see if they are the same size as another size truck, but probably not.
You can have your old shoes relined, and your wheel cylinders are most likely available at NAPA. Or you can have them stainless steel sleeved and install new kits, don't waste your time having them sleeved with brass.
Jim Carters probably has some parts, like wheel cylinders.
It all depends on what you want to do with your truck and how much money you want to spend on it as to weather disc brakes are a good choice.
I thought they were a good choice for my truck, and am glad I switched, but unless you are a good welder, fabricator, and machinist, or know one and have money, you might not want to tackle a disk conversion on a 1.5 or 2 ton.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
get the casting number from old cylinders,the
get casting number from old cylinders,bore is marked on the rubber cup.measure drum diameter and shoe width.number of rivets in shoe would help.maybe can help you
thank you for the help!
Riding in the Passing Lane
The only thing an old Napa catalog shows are, front cyls. part # 3406. Kit #8. Rear repair kit #37. Master cyl. #9220. Kit #33.
1972 Chevy c10 Cheyenne Super
