0 members (), 192 guests, and 0 robots.
Topics128,089
Posts1,056,143
Members48,436
#1525431 11/10/2023 10:40 PM
All new leaf spring shackles arrived and I know it probably doesn’t make a hill of beans difference, but on the original truck were the grease Zirks toward the outside or toward the inside of the frame?
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
Face them in the direction that's easiest to reach with your grease gun when everything is assembled.
1950 Chevrolet 3100 (Ol' Roy)
I don't have a 37 FSM, but for the 55-59 they were on the outside.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Otto, either way is easy to grease, I was wondering how the factory did it 87 years ago.
Larry
37 GC, The lubrication chart from the 1937 Chevy Truck Operations Manual appears to show all the springs lube fittings facing outward. Refer to points 1, 6, 11 and 14 in the chart (point #'s listed on the next page in the manual if you click "Next Page" towards the bottom).
Hope that gives you what you need. thumbs_up
~ Dan
1951 Chevy 3 window 3100
Thanks, that’s what I was looking for.
Larry
