6 members (Rusty Rod, cmayna, Gdads51, 3800GUY, Hugh63c10, 1 invisible), 107 guests, and 4 robots.
Topics128,187
Posts1,057,312
Members48,468
#1525269 11/09/2023 10:31 PM
I messed up and read the instructions.
National Redi-Sleeve Harmonic Blancer Sleeve Installation. Instructions read --- "If the shaft is severely scored, fill the groove with a powdered metal type epoxy filler. The sleeve will have to be installed before the filler hardens." Ever hear of such a thing? Are they talking about JB weld or similar? Are they referring to the grove in the shaft from seal wear?
I was all set to go until I confused myself (easy to do) with the instructions.
Just use red LocTite. It's a liquid, and doesn't need to cure first. Most good quality Speedy Sleeve kits imclude a small vial of it.
Thanks HR. I agree, Red LocTite is my go-to when installing Sleeves. I get a bit uncomfortable however when I discover I'm not following the instructions. I'm still curious about their "metal type epoxy filler " recommendation. This a "National Oil Seals" brand sleeve and not a "who knows what" brand. You would hope they would know what they are talking about.
They're suggesting using a metallic epoxy such as J-B Weld, without mentioning a specific brand name. When I'm installing things like bushings and sleeves that might need a little help staying put, I use a green liquid that LocTite makes specifically for that purpose. I don't recall the part number at the moment, but it's on Ebay on a regular basis. It's not cheap, but it is very effective. I use it for installing wrist pin bushings in connecting rods, and other high load areas. Haven't had a failure yet.
I think what they are talking about is a balancer shaft that has a really deep groove. Those sleeves are thin and so without a little jb weld or marine tex to fill in the gap and get the groove level with the rest of the shaft, the rubber part of the seal will put presure on the speedi sleeve and collapse it into the groove. So the use of the epoxy, wet, serves both a filler and glue purpose.
Mike
Loctite 660 was what I used in industry when the groove was deep. Threadlocker works well when groove is shallow. On some equipment we built, we actually put these sleeves on new.
I take my worn yokes and parts that have a groove where the seal goes to my local machine shop. He sprays them turns them to proper size and they look good as new maybe be better. Some times depending on his mood it does not cost much more than the speedy sleeve and you don’t have to mess with the hassle. Dave
1957. GMC F350
