4 members (Hanks custodian, KEVINSKI, DadsFirstPickup, Ponchogl), 224 guests, and 1 robot.
Topics128,108
Posts1,056,230
Members48,436
#1524938 11/07/2023 4:46 PM
What do you use on the threads of the fitting that screws into the gas tank? Is the Teflon pipe tape you see for home plumbing gasoline resistant? The fitting that screws into my gas tank is leaking around the threads. I can't tighten it enough to stop the leak. I am guessing I need some sort of pipe dope or pipe tape on the threads?
Dave from Northern Kentucky
My 54 3100
dgrinnan #1524941 11/07/2023 5:20 PM
7
7 Offline
Pipe threads are tapered, the design is supposed to get tighter and seal better as you thread it farther into the fitting, some type of sealer is usually needed unless the fittings are brass. Brass is soft and the threads will form pretty well and if the joint is low pressure you may not need sealer. IF the fittings are not pipe thread, such as a flare or inverted flare, the threads do not have any sealing ability, it is the face of the flared pipe against the flare seat that seals. I have used teflon tape sparingly on auto pipe threads, I also have used a gasket sealer such as Permatex Motoseal sparingly on difficult leakes. If your fittings are pipe thread then teflon tape should take care of it, If the joint is in good condition, normal white tape should work, it is thin and fills the microscopic voids in the threads. If the threads in the tank are good, you may have to use a new fitting so you aren't working with worn-out deformed threads on that half of the joint.
dgrinnan #1524942 11/07/2023 5:39 PM
Insomniac
Insomniac
Gord πŸ‡¨πŸ‡¦
1954 1/2 ton 235 4 speed
dgrinnan #1524945 11/07/2023 6:02 PM
Use Permatex Seal Lock.
It combines blue thread locker with thread sealer.
1950 Chevrolet 3100 (Ol' Roy)
dgrinnan #1524959 11/07/2023 8:09 PM
AD Addict & Tinkerer
I’ve used Permatex #2 with great success. It’s resistant to gasoline and oil. Do let it dry at least 4 hours (24 hrs. would be best) before using.
https://www.permatex.com/wp-content/uploads/tds/80016.pdf
Phil
Updated to: β€˜59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes
Project Journals
Stovebolt Gallery Forum
dgrinnan #1525002 11/07/2023 11:45 PM
I also use Permatex #2... thumbs_up thumbs_up
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
dgrinnan #1525016 11/08/2023 1:13 AM
If the threads on the tank and the brass pipe are in good shape, you can put axle grease on the threads which will allow the tapered threads to mesh together to make a perfect seal. The grease won't seal it, it just reduces friction so that the parts will do what they are supposed to do with less force applied. You should use a small pipe wrench for this pipe. Curved-jawed vice grips designed for pipes will work too.
dgrinnan #1525193 11/09/2023 2:07 PM
NPT threads are designed to be used with some type of sealant. When a metal to metal seal is required NPTF threads are used. What's the difference?
NPT (National Pipe Taper) is a general-purpose tapered pipe thread, and NPTF (National Pipe Taper Fuel) is a dryseal tapered pipe thread. Visually, NPT and NPTF pipe threads look identical. Both thread types rely on thread interference for tight, robust connections. This thread interference is made possible primarily by their tapered design.
The two thread standards differ in how they create leakproof seals. Both require proper installation but leakproof NPT connections require the appropriate use of thread sealants. Correctly assembling NPTF connections create leakproof seals without the use of a sealant.
NPTF threads are used instead of NPT when:
The use of sealants could contaminate the fluids or gasses flowing through the system
Applications are critical or the thread sealant might fail because of high heat or high pressure
There are important issues regarding the installation, mixed-use, and reuse of NPT and NPT fittings:
NPT and NPTF fittings can be mixed but this requires using thread sealants
NPT and sometimes NPTF fittings can be reused but only under particular conditions and cautions
NPT and NPTF fittings both have special installation and assembly requirements for leakproof seals
You Tube
dgrinnan #1525234 11/09/2023 6:07 PM
The rest of Curt B's story.
The difference is the clearance at the crest and root of the threads. NPT threads have a little clearance that would need to be filled with thread compound or teflon tape, while NPTF threads have none. See the pic.
dgrinnan #1525256 11/09/2023 8:37 PM
Insomniac
Insomniac
Good info, but how do you tell the difference between NPT and NPTF when you look at them? Are they stamped?
BTW, I have heard that teflon tape is not to be used on our trucks' fuel systems; use dope only. There is a yellow teflon tape for gas such as natural gas or propane.
Gord πŸ‡¨πŸ‡¦
dgrinnan #1525260 11/09/2023 9:11 PM
Sir Searchalot
Sir Searchalot
1. All that goop is too goopy and messy.
2. There is absolutely NOTHING wrong with non goopy Teflon white tape.
3. It does not desolve in gasoline.
4. It's simple
5. It seals
6. If wound in the correct direction, not over applied and a little space left at bottom of threads, it's the best choice for non goopers. Use it.
7. PTFE (DuPont brand name: teflon) is non soluable in about every substance/chemical/solvent on earth.
8. Goop can get into any place you think teflon tape can get into. Don't finish the "tag end" at the bottom of the thread. Start the wrap several threads up from bottom and wrap upwards away from bottom of threads so as not to shear tape at bottom of threads.
9. Always cut tape with scissors to make a clean non stringy end, on both ends.
10. House plumbing may have a different set of methods/opinions.
dgrinnan #1525291 11/10/2023 12:58 AM
What do y'all reckon GM used there 70 years ago?
52Carl #1525301 11/10/2023 1:31 AM
Sir Searchalot
Sir Searchalot
Connections were USA made, quality threads.
dgrinnan #1525331 11/10/2023 11:52 AM
7
7 Offline
I totally agree with bartamos, especially with following the teflon tape application procedure.
dgrinnan #1525341 11/10/2023 1:20 PM
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
