1 members (Bill Hanlon), 95 guests, and 4 robots.
Topics128,181
Posts1,057,184
Members48,465
Need some mentoring on how to convert Rpm to vehicle speed. I have a 53 3100 with a 54 truck engine and the 4.11 rear. I currently have 235/70/15 on all 4. I have tried the online converter posted here but no luck. I would like to know that at a RPM of 2000 what would my actual speed be. Thank you for you help.
Your tires with that size turn 745 times per mile (got that from Tire Rack's specification page for a tire of that size). So at 2000 RPM engine speed, the tires would be turning 487 rpm (2000/4.11), or 0.65 miles per minute (487/745). Mulltiply that by 60 min per hour and you get 39 miles per hour.
I think we still need more info to make the calculator work out (guessing you are referring to the one in this Calculate RPM Tech Tip ).
What transmission are you using (output final drive)? If you have an overdrive transmission, that affects the output RPMs.
What is the overall height of your tire (not all 235/70/15's measure the same)?
EDIT: Kevin beat me to the punch. Still need to confirm on the questions I asked though as they can make a difference. smile
~ Dan
1951 Chevy 3 window 3100
eDan; The truck has a stock 3 speed and overall height of tire is 27 inches. Thanks to all for the reponces. Dave
rpm÷ratio (4.11) x tire circ (in feet)x 60 ÷ 5280.
My 54 3100 3.90 rear, 7.5ft circumference tires...
2000÷3.9x7.5x60÷5280=43.8mph.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
Circumference = Pi X Diameter- - - -27" height X Pi (3.14) = 84.78 inches. Round off to 85 inches. 85 inches = 7.08 feet. 746 turns/mile.
It should be simple to plug un the figures from there with any of the online formulas.
Dave,
Below is a screenshot of your “numbers” plugged into the calculator and computed result.
Looks like just a smidge over 39 MPH with given data. smile
~ Dan
Where is that calculator? Is it on this site somewhere?
1950 Chevrolet 3100 (Ol' Roy)
Results for the OP's question on the calculator that EchoBravoSierra posted.
Thank you all for the info and illustrations and site! This web site and member have a wealth of info. Haveing owned a 54 & 53 3100's in my younger years never worried much going down the road at 50mph and wondering about engine rpm. Thanks!
Otto,
See the Online conversion.com link towards the bottom of the page in this long standing Driveline Tech Tip from 1 March 2008. thumbs_up
~ Dan
Thanks. That's quite useful.
I am curious as to why you would like to know specifically what speed you are going at 2000 RPM.
There engines give more bang for the buck considerably above 2000 RPM. The sweet spot is between 2400 and 2600 RPM in my experience. Upwards of 3000 is not an issue either if you need to go highway speeds from time to time.
These engines tend to lug at 2000 RPM.
Dave and everyone participating in this conversation. Since the conversation seems to be continuing, this topic is more related to your/our trucks “driveline” so I have moved the thread to the Driveline forum.
Best Regards! 😉
~ Dan
On your cell phone download viewpoints, speedometer. It is a GPS electronic speedometer.
Thanks to all for the input. I was trying to verify mph vs rpm in my truck.When I take the spped up to 50,55 my tack is reading in the range of 2500 to 2800. I usually try to keep under 3000 but it will takemore and not hesitate-----however the engine noise picks up quite a bit. I will do the download on cell as suggested------Happy Motoring to all!----Dave
Do you have a running tachometer in your truck? If so, download and use "Speed Box" (a GPS app) for your speedometer.
Craig
Try making a run with the fan removed- - - -it's not needed above about 40 MPH anyway- - - -and I think you'll be able to figure out where the extra noise is coming from.
I am going to follow HRL advice------I am going to change oil & grease Wed so I will pull the fan and take a run and then chage the oil. Dave
