1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#1524640 11/05/2023 1:27 AM
Hi all. I have developed a pretty good oil leak. However, I cannot determine exactly where it is coming from. I did notice that when I pulled the dipstick, the oil smelled like gasoline. I ran the truck and warmed it up good and again inspected for where the leak was coming from and could not find it. Lot of oil blown across the bottom half of the engine and oil pan. I drained the oil and it wreaked of gasoline. What would cause gasoline to be getting in the oil?
Darrell Day #1524641 11/05/2023 1:46 AM
Mechanical fuel pump diaphragm has a crack and pumping fuel into the engine. Age of pump and also today's fuel can cause this. Avoid today's new fuel pumps, visit Then and Now Automotive for repair of current pump. Advise not to drive. I had this to occur, one side effect is it tends to remove engine sludge upon draining oil.
1952 Chevy Pickup Truck
Darrell Day #1524642 11/05/2023 1:55 AM
Yes. Everything papa said.
Send your original fuel pump to Then and Now Automotive for a rebuild. New ones aren't worth a plug nickle.
They rebuilt mine a year or so ago and I've put many thousands of miles on it.
If your fuel pump is a new pump, find an original pump or one built in the USA 30 years or more ago and send it to T&N.
1950 Chevrolet 3100 (Ol' Roy)
Darrell Day #1524647 11/05/2023 2:55 AM
Ditto on the leaky fuel pump. Most fuel pumps have a hole in the lower housing that lets at least most of the leak vent to the outside before it makes its way into the crankcase. That also accounts for the oily residue along the bottom of the engine. Air blowing over the fuel pump housing pushes the leak back along the oil pan.
Darrell Day #1524850 11/07/2023 12:32 AM
Thanks all. I have the fuel pump off. It is a Carter MO 735 Made in the USA. Is it one that is worth having rebuilt by Then and Now Automotive? If not, what are my options since it looks like buying a new one is a waste of money? I've attached pictures of the current one I have.
Darrell Day #1524852 11/07/2023 12:40 AM
I believe they can rebuild any bolt together fuel pump, give them a call to confirm.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Darrell Day #1524860 11/07/2023 1:50 AM
Yes, they'll be able to do it. They only take calls on Monday and Thursday so you'll have to wait to speak with them. They are way behind and short handed. It took them 2 months to do a Cadillac pump for me recently. Works like a champ, though.
Darrell Day #1524907 11/07/2023 1:09 PM
As I understand it, one of the problem with today's fuel pumps is the actuator arm with its mate to the cam and movement of the pump diaphragm. Repair of your pump seems feasible. I looked up pump number on their web site, ordered it's kit and rebuilt mine. First time I rebuilt one, works great for past 3 years.
Darrell Day #1524911 11/07/2023 1:49 PM
I believe Then and Now also sells the rebuild kits if you don't want to wait and are confident doing it yourself. I agree with everyone about rebuilding and not buying a new aftermarket. There are probably other options besides Then and Now but I am on my 3rd after market fuel pump. When I got my truck, it did not have a fuel pump and this is before I new about the issues of the after market pumps. With less than 2 hours run time the first pump failed. I bought a second pump. Less than 10 hours of run time and failed. I am on my third fuel pump. So far, so good. If this one fails I am going to source an original and have it rebuilt, or go 100% electric.
Dave from Northern Kentucky
My 54 3100
