9 members (dt235sd, Jon G, Gdads51, mick53, 4tttt8, Leo, Otto Skorzeny, TUTS 59, 1 invisible), 87 guests, and 5 robots.
Topics128,181
Posts1,057,177
Members48,465
U
U Offline
Getting ready to install in a medium duty (class-7) dump truck.
I have never seen one installed. So i am alittle lost.
It is divorced / It has mounting ears at rear, the cross member holds these ears and a disk type E-brake.
My big question is: What holds up/steadies the front of trans ?
A: modify input/output no u joints just straight coupeling and hang it off the rear of main ?
B: use a carrier bearing close to input?
C: Fab a front cross member and a mount for input flange ?
D: It will be fine hanging from to rear only ?
E: ??????
Pictures are always very helpfull
3B Offline
Hy underdog,I'm afraid the answer is "E", there should be a circular mount for the front of the trans with a two bolt flat flange mount which attaches to a crossmember. Between the two transmissions is a short connecting shaft with two "U" joints in phase, and it is usually collapsable, as much as a shot shaft can be, hope that helps, if you need more info just ask.
U
U Offline
Yes that helps.
Where can i find a picture of said item ?
The front crossmember goes over or under ?
Is there isolation rubber at crossmember ?
3B Offline
Hy again underdog, both crossmembers are above the trans. there are supposed to be isolation rubbers at all four mounts . I'm not a computer guy, but I'll see if my partner can post what pitiful drawings/pictures I can find
3B Offline
Hy underdog, here are the illustrations I could find on installing the 6041 auxilliary transmission, hope they help, any more questions just ask
[img]http://i120.photobucket.com/albums/o178/pintos4me/auxtrnmt2.jpg[/img]
[img]http://i120.photobucket.com/albums/o178/pintos4me/auxtrnmt1.jpg[/img]
[img]http://i120.photobucket.com/albums/o178/pintos4me/auxtranmt.jpg[/img]
3B Offline
Ooops. Here is the one which was upside down.
Sorry.
:o
U
U Offline
Thats a big help.
So the front is a support collar.
Thank you very much.
I have info on ratio"s and such but cannot locate
load capacacity.
Do you think this box will hold up to 40,000# loads,
Motor puts out:
210hp @ 2600rpm, 509ft/lb torque @ 1600rpm,
The model 6041 means 600ftlb of torque, and 4 speed, and I think the one means auxiliary transmission.
So a 5831 is 580ftlb and 3 speed, a 7041 is 700ftlb and 4 speed, a 1241 is 1,200ftlb and 4 speed.
What I don't know for sure is if the torque rating is engine torque, or engine torque multiplied by first gear ratio in main transmission. If it were the later I think even a 235 with a 7 to one first gear is to much engine for that transmission, and I know they were put behind larger engines than that. So it sounds likely that the torque rating is for engine torque.
I imagine it will hold up fine in your application if you are careful, but a 7041 is probably better suited to your job.
I would install a temp gage and keep an eye on it, you are more likely to kill with high temps while pulling a load than with a sudden catastrophic failure, or if it is catastrophic the high temp will give you a warning.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
