4 members (Jon G, Gray_Ghost, Bill Hanlon, MRMEROTH11), 85 guests, and 0 robots.
Topics128,068
Posts1,055,881
Members48,428
#15242 06/14/2002 1:56 PM
Junior Member
Junior Member
My '52 is basically stock with the 216 & 4 speed. I need to make it a reliable daily driver - it doesn't have to be fast, but does need to do 65-70 without destroying the motor. Having done some research on upgrading the torque tube, and seeing its probable cost ($700+ just for parts), I'm thinking replacing the whole works with more modern alternatives. Long term design is a small V-8 (V-6?), either manual or auto overdrive tranny, an open driveline (obviously), and disk brakes. My wife will be driving it more than I, to "tool around town". I would like to keep as much of it original as possible (i.e. I don't want to drop the cab onto a modern frame as as been one suggestion I've gotten). I'm all ears on this one - thanks.
#15243 06/17/2002 12:06 PM
You might consider buying a donor car a camero or nova. You can then drive it around and see how it runs. Then just swap all the parts.
if it dosen't need fixed, break it
#15244 06/17/2002 8:08 PM
Junior Member
Junior Member
Thanks Kedso - very interesting suggestion. I've got a '69 RS/SS 350 Camaro about 95% restored now (is anything ever 100%?). Good suggestion.
- rick
#15245 06/26/2002 2:35 AM
V
Junior Member
Junior Member
V Offline
I have a 52 panel with a 350/350,and the stock rear end from a mid-70's 1/2 ton. I wish I had either an auto trans with overdrive or had used a good 5 speed with a big overdrive gear, like a New Venture 4500. Don't put in a 350 hydro-- the gas mileage and engine revs are not pleasant.
Now I am building a 56 3/4 ton, and that is what I am doing-- computer controlled small block and a NV 4500. But don't dream that you are going to come out of this for less than $700. It will cost several times that, even if you use mostly new parts.
My "new" 56 has no motor, so I have to do something. When I changed over my 52, the new tall rearend gears were not available. If I were to do it now, though, I would keep the original engine and change the gearing. It is just a cleaner job, and just as nice to drive. I have power discs now, and they are not enough better than the stock brakes to merit the money and effort it took to make that switch, either.
Vttinkerer
#15246 06/28/2002 5:08 PM
Junior Member
Junior Member
Thanks Vttinkerer, for the comments. I'm figuring $2500-$4000 for converting the whole thing using a mix of new & used parts. Still haven't made any purchases yet. My current project to do is reconditioning the leaf springs and shackles. What does the weight of a V8 do to the front springs? Should I be looking for them as well?
#15247 06/28/2002 6:00 PM
Junior Member
Junior Member
Hi Rilap,
I also have a 52, 1/2 ton that is all original. I am going to be swaping out the drivetrain as well. My thoughts are to go with a Heihts IFS, keep the 235 ci and use an adapter kit for a 700R4 tranny. Also, I'll have to swap out the rear end as well and install Mono leafs in the rear. This swap also mean I'll need a new steering column w/shift. The questions I have are:
Will I have to cut the firewall or floor in order to get the 700R4 in?
Anyone out there ever done this? I have installed a T350 trans a 53 Chevy PU without having to cut the floor.
#15248 06/28/2002 6:25 PM
I guess the more guys hack their's up, the more mine will be worth. eek
54 3100 with 235
62 flatbed dump C60 with 261
#15249 07/02/2002 1:56 AM
hello rilap. i think the small block chevy v8s actually weigh less than the 216 straight sixes. your reconditioned spring sets will help handling reguardless of what engine you decide on. you said it would be used to tool around town and must go up to 70mph. wo nelly! i've read on this forum that a front sway bar and front disc brakes do alot to improve handling and stopping on straight x trucks, and i will soon be doing these improvements on mine even though still using a 235 six. good luck
our garage is a non-profit organization
#15250 07/03/2002 9:06 PM
Junior Member
Junior Member
Thanks Gary G for the additional input. The parts are starting to pour in. As for Tony M, I'm planning on keeping my stock drivetrain just in case...
- rick
#15251 07/03/2002 10:43 PM
Good, do stuff you can bolt on and off. But just don't cut off the front. smile
54 3100 with 235
#15252 07/07/2002 6:33 PM
Junior Member
Junior Member
Mind if I chime in? I am planning on buying a 53 GMC chassis complete with must 2 front, v8 eng mounts, etc already there to put under my 50 chev pu. I now know that the radiator support is different, but my question is how much and in what direction should the rear axle be moved to center it with the fender openings when I lower the rear about 2 inches? I have read that moving the axle forward about 3/4" will do it. Any comments? Thanks,
Roy
#15253 07/07/2002 6:49 PM
Anonymous
Unregistered
Anonymous
Unregistered
Typically, the stock rear end location is already forward and need to be moved back to center in the fender.
#15254 07/08/2002 1:38 AM
Junior Member
Junior Member
Thank you for the info. I was hoping my eyesite was telling me that the axle needed moved rearward. I have a "How to Build" magazine special that stated to move it forward 3/4", but in my eyes, looking at my stocker said to the rear a 1/2" or so looked right. Thanks, again.
Roy
