3 members (KCMongo, HelmutVonSchet, 59 fleet), 90 guests, and 0 robots.
Topics128,049
Posts1,055,679
#1524580 11/04/2023 1:02 PM
8
nothing beats a try but a failure
8 Offline
I was looking for a product that would provide sound deadening and thermal insulation to the inner fire wall, under the floor and the inside of the back wall. Lizzard Skin is what I used. LS is designed to be applied over primer not directly to metal. It is sprayed on. First I applied the sound deadening product and let it cure for 24 hrs. Then, the ceramic coat comes next. The results are as described. It did make the sound of the panels quieter and I have not tested the thermal qualities as of yet. I posted some pictures.
1955.1 3600 5 window 4 speed all original except the 410 gears.
In the Project Journal
87GN #1524608 11/04/2023 7:10 PM
Nice work on the undercoating. Looks better than my rattle can job.
It also looks like your cab rotisserie is similar to the one I built. I also used the door hinge and striker bolt locations for the pivot brackets. Those are now being used by another bolter for his project. It sure makes things easy to get at.
87GN #1524624 11/04/2023 11:12 PM
Look exactly the same as the stuff I used. Liquid asphalt.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
