7 members (Shade Baby, GMCJammer51, 2-Ton, 3800GUY, IHPWR, Jon G, Hush), 208 guests, and 1 robot.
Topics128,102
Posts1,056,185
Members48,436
#1524498 11/03/2023 7:27 PM
A fellow bolter is sending me a Muncie 318 3spd transmission in a few days.
He notified me that the imput shaft bearings got rusted over the years and needs to be replaced.
My question is if I remove the nose and side cover is there a way to replace the bearings or does it have to be completely torn down?
Also is the imput shaft bearings available?
Jim
1950 chevy shortbed 3100, 216 with a 3 on the tree.
Yes, you can pull just the input shaft to replace that bearing. You might not even need to pull the side cover, but I'd do that just to check and make sure things are in good shape inside. These trannies are pretty simple and not much in the way of special tools needed for a complete teardown and rebuild.
There's a retainer nut that secures the bearing to the input shaft with a left hand thread which requires a special thin open end wrench to remove it. If you like, I'll loosen the nut and see if I can free up the bearing on the shaft before Don picks up the transmission. I might even have a good used bearing stashed away somewhere. I'm not sure if the SM 318 and the torque tube earlier trans runs the same ball bearing. Here's an Ebay listing for one I believe will fit.
www.ebay.com/itm/353876789484?
6 heaven
6 heaven
If I understand you, the big bearing needs to be changed on the input shaft. Be careful not to pull the shaft out too far because there are internal needle bearings in there that you can't see on the inside of that input shaft.
Here's the parts listing for the input bearing. That should help get the right one.
And yes, you need to make sure the rollers inside the input shaft stay in place, so taking the side cover off would be good insurance to keep from those dropping into the case.
PM your email address and I'll send this:
I'll call you when I receive from Don.
No need to loosen nut. I'm going try doing it my self, gotta learn some day.
I'm sure I can count on you for advice once I start.
Jim
Pm sent
That is a standard 6207N bearing used in both the closed and open driveline 3 speed transmissions.
It's certainly not an $80 part. At most about $30 where I get my parts. That bearing is pressed on the
shaft and then the left hand slinger/nut is installed. It's going to be difficult trying to remove and
reinstall a pressed on bearing without removing the clutch gear.
Fred
