2 members (moparguy, Gray_Ghost), 109 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1523477 10/25/2023 8:53 PM
Hi, A friend gave me this motor said it was a 400. Code on the pad is TO325CTD I could not find any info on it any help would be great. Thanks Steve
7
7 Offline
You should also find a casting number on the block, rear left just above where the bell housing mounts, how many freeze plugs are in the side of the block?
I will look tomorrow when I get to the shop Thank you
Insomniac
Insomniac
Decode it here: https://nastyz28.com/chevy-engine-code-stampings.php
You have a 400 originally installed in a Caprice with automatic transmission and 4 bbl carb. 175 HP. Built March 25 in the Tonawanda plant.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
A 400 will have a very large harmonic balancer, with a weight cast into one area- - - -those engines need to be externally balanced. Ditto for a flywheel or an automatic trans flex plate- - - -there's a balance weight on it if it's on a 400. The "T" prefix on the engine number generally means it's s truck engine- - - -probably with 4 bolt bearing caps on the number 2,3, and 4 main bearing webs.
Thank you for the info I will pull the pan and check what Hotrod said and get more numbers from the block. Thanks again Steve
CTD could either a 1974 400 or a 1978 305. Scroll down the chart till you see CTD.
http://www.1968ss.com/sbcsuffix.asp
Also run your hand down the side of the block. 305 will be flat. A 400 will have slightly protruding lumps because of the larger bores. 400 will have a notch cut out of the harmonic balancer, because it's externally balanced.
Brian
1955.2 3100 Truck
Hey Steve, did you ever figure what you had?
Brian
1955.2 3100 Truck
Been away for a while yes I did thank you.
